I have an original H1 that I want to sell.
I consider it "non- functioning" because I've never been able to get the extruder working consistenetly. I've killed 2 hot ends and I'm tired of trying to get it working. So I bought a different 3D printer.
If you're interested, Make an Offer.
I attached one picture. If you'd like to see something else, email me.
Here's the description:
1) Original H1 assembled per instruction - then tweaked. Temporary wiring.
2) Misc extra hardware that came with the kit.
3) H1 roller bearing upgrade installed.
4) Frame extension to accomodate headed bed
5) Prusa 8"x8" Heated Bed
6) Gen 6 electronics.
7) 4 stepper motors with short shafts ~1/2 " installed. (These are shorted than recommened, but the have worked so far.)
8) Brick style power supply (from old laptop.)
9) ~1 Kg Roll of 1.75mm PLA, color = clear.
If you buy it you will definitely need to:
A) Fix the extruder hot end. You may need to buy replacement parts.
B) Finalize the wiring
C) Tweak and Adjust the whole assembly to meet your needs.
D) Finalize and mount the Heated Bed.
I do not recommend this for a first timer. It would probably be a good project for another H1 owner. No Refunds or Returns.
Please do not request additional photos unless you're serious.
Thanks,
-Geoff
Make an Offer: Non-Functioning H1 w/ extras
Re: Make an Offer: Non-Functioning H1 w/ extras
Hello Geoff,
Sorry to hear you had such a hard time with the extruder, i must admit it took me quite a while to get mine working.
I am interested in your machine and am wondering what you are looking to get for it.
Thanks,
Anthony
Thanks,
Anthony
Anthony Leander
Running the Creeper Creator
I feel ya, annoying as hell, took me months to get my first good print and now I'm waiting on parts again.
Anthony! Good to see you around. Hope all is well over there. tom, did you send an order in , or an email?
john, i found some thicker heating resistors on ebay i am going to try out,same wattage and everything
by thicker, you mean larger diameter?
sorta, they are not rounded on the edges like the others so you don't need the v shape
Still available?
SOLD.
Thanks to all who inquired.
-geoff
-geoff
martinezfrank95
- Plasticator
how much do you want for the h-1 with all the extras if you still have it
