ORDER PLACED!!!! - Rostock MAX v3
Posted: Thu Aug 25, 2016 3:47 pm
by cloneit3d
I realize this post serves no purpose - just extremely excited to have placed my pre-order!!!!!!
:D :D :D :D :D :D :D :D :D :D
Re: ORDER PLACED!!!! - Rostock MAX v3
Posted: Thu Aug 25, 2016 4:08 pm
...and if you're really lucky, I'll have the docs done by the time they start shipping. :D
Posted: Thu Aug 25, 2016 4:35 pm
geneb wrote:...and if you're really lucky, I'll have the docs done by the time they start shipping. :D
"Fat Chance" :)
Posted: Thu Aug 25, 2016 4:48 pm
Well there's always the "JJ changed something" factor. :)
I DID pull off a neat trick (well for me anyway) - the docs will now feature a 1:1 scaled & dimensioned hardware chart so there will be no doubt as to what size & type of fastener is required for a step. You can print the page out and actually measure the drawing on paper and it'll match what your ruler says. :)
Posted: Thu Aug 25, 2016 4:50 pm
That's cool and useful!
Posted: Thu Aug 25, 2016 6:11 pm
by Eric
It's way more fun putting things together without a manual anyway.
Posted: Thu Aug 25, 2016 6:19 pm
by Xenocrates
Eric, True fun can also come from assembling them with the wrong manual, with a poorly translated one, or making someone else do it with those same constraints. One of my eternal favorites is a chinese laser cutter. Want to guess what 'Install Soft Dog' means in the context of getting it working?
Posted: Thu Aug 25, 2016 6:50 pm
by Noircogi
I'm on the list also. Looking forward to joining the delta family. I was refreshing the we site waiting for orders go to live. :) SeeMeCNC was good enough to retro-actively apply John's discount code after he posted it.
Posted: Thu Aug 25, 2016 8:01 pm
by cloneit3d
Hmmmm discount code? Do tell-
I was under the impression the underside of the melamine is porous and was thinking about applying spar varnish. Would someone please comment on that?
The only thing I am lot looking forward to is Arduino- I have been spoiled running Smothieware.
Gene- love the idea of the scale hardware document!
Cheers!!
Posted: Thu Aug 25, 2016 9:44 pm
by Qdeathstar
well, the melamine is sealed except for the edges, which can be easily painted... I only touched a spray-can 2-3 times prior to the Rostockv2 and was able to get a good looking job...
The electronics are fairly easy to upgrade.... I wish they would have upgraded to 32bit electronics, have been able to keep the price at 999 despite adding quite a few features so that's commendable... when I first saw $1899 for the v3 I thought that was crazy... then I realized it was fully assembled and with the pi.
Posted: Fri Aug 26, 2016 7:34 am
by Mac The Knife
cloneit3d wrote:Hmmmm discount code? Do tell-
Cheers!!
If they are using the same material as the V2, both sides are covered with melamine. Just the edges are exposed, and they soak up paint like a sponge.
Posted: Fri Aug 26, 2016 8:16 am
I've used Killz Primer in the past to seal the edges. Other folks have used 1/4" wide, colored pinstriping tape. YMMV. :)
Here's the hardware chart:
full size screw drawings.PDF
(183.38 KiB) Downloaded 418 times
Posted: Fri Aug 26, 2016 11:13 am
by cloneit3d
Thanks for the tips on the melamine guys!!!! I will apply the colorless spar varnish on a test piece and see if there are any ill effects.
Cheers!!!!
