Heat Bed Sensor
Posted: Sat Jun 07, 2014 7:42 pm
by bertropro
Does anyone know how to disable the bed sensor test on boot up. I assume it would be in the firmware EPROM setting but I'm not seeing it. I have a thermistor issue and I would like to run without the heated bed until I get it fixed but it errors out and goes into dry run mode because of the heat bed sensor failure. My other two printers are easy to run without heating the bed but this one is a little more complicated.
Re: Heat Bed Sensor
Posted: Sat Jun 07, 2014 8:02 pm
by mlapaglia
There is a setting in the configuration.h file to disable the heatbed, just set it to 0.
Re: Heat Bed Sensor
Posted: Sun Jun 08, 2014 1:11 pm
by bertropro
Thanks. Is that file located in the Repetier host or where?
Re: Heat Bed Sensor
Posted: Sun Jun 08, 2014 1:15 pm
Yes, assuming you are using Repetier firmware it is in src/ArduinoAVR/Repetier folder
