Okay, so everything is completed and I did my first two prints last night.
The first print was the fan shroud, and to my untrained 3D eye it looks pretty good. However, I had to use the irwin vise clamp to push the fan in it is so tight,
and in fact the fan does not turn because it is overly tight.
So since it was 1:30 and I wanted to go to bed, but leave it printing something, I left it printing 'tower of pi, fixed smaller' from the thingyverse. and went to bed.
I had some problems centering it in the build area, I think it was because it started by placing it next to the fan shroud, and then I deleted the shroud, and then I put in some new offset values to try to move it back to the center.
It was not close to the center, in fact it was just about offset so the edge of the object was the center.
This morning, I find the message 'killed' on the printer, and F&@$ing windows looks like it decided to reboot, maybe about 1/2 way through the print.
I knew this print was going to be challenging, with many many extruder retractions.
Okay, it seems obvious now that I rushed through the bed flatness adjustment (delta radius?), because farthest from the center of the bed the part got kindof squashed .
(I am working on uploading the picture to attach here - the JPG is 16MB)
Here is the full res version, which should provide all the data needed if you download the full thing and zoom in
https://www.dropbox.com/s/58nzdnh23hixq5q/_6001443.JPG
I had the camera ISO cranked way up so I could take the image at F16 handheld no flash - but with a macro lens. I'll be working on getting better photos of these prints, too.
(actually the flash doesn't work so good with macro close ups, I need to get a ring flash. Or pull the tripod in (it is outside with a bird camera on it right now).
So, any suggestions?
