Re: Clunking Noise???
Posted: Thu Jun 05, 2014 7:25 am
the only difference between the new hotend and the one you are using is the PEEK section.. the new peek can use the same nozzle and top section, but uses only a single ptfe liner rather than the double. If you wanted to change to the new style all you would need is the new peek from http://seemecnc.com/collections/parts-a ... nc-hot-end and you would eliminate the double liner.
depending on which hotend you have, the other thing that changed is a thinner heating block, but the new peek can be used in either...
Guanu
Guanu
