Page 2 of 2
				Re: help, my printer is posessed
				Posted: Tue Oct 14, 2014 4:45 pm
				by Mac The Knife
				Max V2 has the extruder motor mounted up top, unlike your V1.  There exists the chance of crosstalk between the stepper wires, and the endstop wires on the V2s.
				Posted: Tue Oct 14, 2014 5:22 pm
				by Aurora900
				Oh, its a v1?  I missed that bit of info... also didn't know there was a difference there anyways
  Sorry about that!
				Posted: Tue Oct 14, 2014 6:39 pm
				by DavidF
				well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
				Posted: Tue Oct 14, 2014 7:21 pm
				by Mac The Knife
				DavidF wrote:well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
The joke about how many psychiatrists do you need to change a light bulb just came to mind,,,,,
				Posted: Tue Oct 14, 2014 7:27 pm
				by DavidF
				Mac The Knife wrote:DavidF wrote:well quite honestly I struggle thru with the electronics end of things, but if you dont mind spending a bit of time with me I would do my best to help you sort thru this problem. I would also make you go thru the things you have all ready went thru for trouble shooting purposes and even though you have all ready went thru them I would expect you to do it again and not just fake it and say yes its this. But you have to be willing to spend some time sorting this out and not just looking for a quick answer.
  I must have missed the punch line....
				Posted: Tue Oct 14, 2014 7:28 pm
				by Mac The Knife
				,,,,, Only one, but the bulb must want to change.
				Posted: Tue Oct 14, 2014 7:46 pm
				by DavidF
				Mac The Knife wrote:,,,,, Only one, but the bulb must want to change.
  Oh great!! color changing bulbs!!
				Posted: Tue Oct 14, 2014 8:03 pm
				by Mac The Knife
				I finally watched the second video posted, and because of the sporadic movements, I'd also say that you may have some electrical crosstalking going on, just not up top.  I would suggest checking all the wiring down below, and isolate the stepper motor wires from the rest of the wiring.
If that doesn't work, see if you can convince someone to test your board on their machine.
				Posted: Mon Nov 17, 2014 10:50 am
				by neorpheus0
				I have tried isolating the endstop/stepper wires from one another as best I can in the limited confines of the electronics bay with no apparent change in behaviour. I'm tempted to try throwing ferrite donuts on the endstop wires just to see if it makes any difference. Thoughts on this?
				Posted: Mon Nov 17, 2014 11:03 am
				by dtgriscom
				neorpheus0 wrote:I have tried isolating the endstop/stepper wires from one another as best I can in the limited confines of the electronics bay with no apparent change in behaviour. I'm tempted to try throwing ferrite donuts on the endstop wires just to see if it makes any difference. Thoughts on this?
I have mixed feelings about this:
- That probably would kill any crosstalk between the steppers and the endstop wires (if you put the chokes near the RAMBo)
- This really shouldn't be necessary if you're keeping the wires separate, but given the trouble you've been having...
Dan
				Posted: Mon Nov 17, 2014 11:52 am
				by neorpheus0
				Well it's only a few bucks for a cheap pack of chokes from the regular places so i'm not really out anything if they don't work.  however i've never had to incorporate them into a build before so i don't know if there is some particular size or something i should be looking for.
				Posted: Thu Dec 18, 2014 9:07 pm
				by neorpheus0
				Well it turned out that the chokes didn't help at all, it was in fact a grounding issue causing the gremlins. at this point i should be ready for my first print but slice3r is generating some funky gcode. i mean the test cube looks right and everything but it is trying to print it centered on the edge of the bed between the X and Z towers. any thoughts of great oracles of the interwebtubes?
				Posted: Fri Dec 19, 2014 12:11 am
				by lightninjay
				Check to make sure your slicer machine settings are configured for a round bed with 0,0 at center.
				Posted: Fri Dec 19, 2014 3:54 pm
				by neorpheus0
				Yup, i feel smart. it was in fact the printer bed settings. about to try for my first print, woohoo
				Posted: Fri Dec 19, 2014 5:54 pm
				by lightninjay
				Oh what a journey it's been!
Let us know how it goes!
Too many people solve their problems and fail to come back here and celebrate their victories with us all; instead they often end up just sharing their failures.  We all like to appreciate the little victories here and there
				Posted: Fri Dec 19, 2014 11:40 pm
				by neorpheus0
				Haha ill be sure to share the victories when they come, but it looks like today is still not the day. something is still screwy with my PRINTER_RADIUS. the nozzle sits a touch further above the center of the bed than it should. it seems like changing the PRINTER_RADIUS value isn't affecting the nozzle height either. i'm lost...
