Page 3 of 8
Re: Trick Trucks - Lightweight Aluminum Carriages by Trick L
Posted: Tue Nov 25, 2014 11:57 am
by RegB
Thanks Brian,
Thanks also for also replying to my REDUNDANT pm on this (-:
Posted: Sat Nov 29, 2014 10:44 am
by jmpreuss
I don't remember seeing a date anywhere but it appears the $10 off pre order special has now expired.
Posted: Sat Nov 29, 2014 2:22 pm
by RegB
I *HOPE NOT*, since I am on the web site now and it is saying order now and save $10.
Posted: Sun Nov 30, 2014 9:18 am
by RegB
Ooops, I put them in the cart just before some "system problem" and y the time I got to check-out the $10 off was gone.
Maybe jmpreuss was right all along - though the web site STILL says anticipated ship date is Dec 12 and $10 off is available on pre-orders.
Probably still worth $50, but I'll hold for now.
I guess I'll amuse myself with the astrosyn damper upgrade/re-build - those should be here early this week.
by RegB
RegB wrote:Ooops, I put them in the cart just before some "system problem" and by the time I got to check-out the $10 off was gone.
Maybe jmpreuss was right all along - although the web site STILL says anticipated ship date is Dec 12 and $10 off is available on pre-orders.
Posted: Mon Dec 01, 2014 5:01 pm
by bvandiepenbos
$10.00 off Sale extended to December 13
http://www.tricklaser.com/Trick-Trucks- ... TRUCKS.htm
Also, if you have not ordered your wheels & hardware from Open Builds they have 15% off TODAY.
Use Coupon Code OpenBuildsCM15 to receive 15% off your entire order.
http://openbuildspartstore.com/
(parts list on Trick Laser site)
Posted: Mon Dec 01, 2014 5:38 pm
by 0110-m-p
Thanks for the 15% off heads up. Just placed my order for $48.62 shipped.
Posted: Mon Dec 01, 2014 8:36 pm
by bvandiepenbos
0110-m-p wrote:Thanks for the 15% off heads up. Just placed my order for $48.62 shipped.
your welcome. no problem.
Posted: Wed Dec 03, 2014 8:59 am
by RegB
Thanks Brian,
I flipped AGAIN and ordered mine.
Only hang up is that the 625RS bearings seem to be in VERY short supply - and there isn't an EASY way
to know how many you can get, only that you are trying to buy too many.
Heck, I got THREE, so only FIFTEEN to go (-:
Not your problem, but they don't have an easy way to back order either.
Anyway, ~$80 plus whatever I have to pay for the other 15 bearings,,, wherever I can get them.
Looking forward to this.
Posted: Wed Dec 03, 2014 10:15 am
RegB wrote:Thanks Brian,
Have you seen these:
http://www.thebigbearingstore.com/servl ... all/Detail
Posted: Wed Dec 03, 2014 1:01 pm
by jdurand
There's always these guys for bearings too.
http://www.vxb.com/SRCH.html?Store_Code ... ch=625-2RS
Sometimes they'll have the bearing priced individually and then again by the bag/box for less.
Posted: Wed Dec 03, 2014 1:27 pm
by 0110-m-p
Posted: Wed Dec 03, 2014 2:14 pm
by bvandiepenbos
Thanks for the bearing sources guys.
Another option is to order the OpenBuilds V-Wheel "Kits" and add shims, eccentrics, and longer screws. It ends up about the same price (maybe $1-2 more) then you end up with (9) extra 5 x 25 screws.
Order this way...
(27) x Precision Shim - 10x5x1mm
(3) x Eccentric Spacers (Length: 1/4")
(1) x Low Profile Screws M5 (Length: 30mm/10 Pcs)
(9) x OpenBuilds Solid V Wheel Kit
I have had to do that sometimes they don't stock individual bearings, but DO have wheel "kits" in stock.
Screen capture of buy list attached also.
Posted: Wed Dec 03, 2014 5:53 pm
by RegB
Hmmm, 4, 5, or 6 bux a piece in some places.
A little under $3 if I buy wheel kits, but I would need 8 kits and get a lot of bits left over, since I already bought everything else.
A dollar each, but they are out of stock of the "BEARINGS ONLY" at OpenBuilds - though they have enough to make up 8 kits.
I'm trying to get them to back order for me, since the trucks are in any case 9+ days away.
Posted: Wed Dec 03, 2014 8:55 pm
Could someone post the stl file for the belt clips, I seem to have lost it along with my mind tonight.
Posted: Wed Dec 03, 2014 9:10 pm
by bvandiepenbos
Eaglezsoar wrote:Could someone post the stl file for the belt clips, I seem to have lost it along with my mind tonight.
here ya go Eagle
http://repables.com/r/424/
Posted: Wed Dec 03, 2014 9:52 pm
bvandiepenbos wrote:Eaglezsoar wrote:Could someone post the stl file for the belt clips, I seem to have lost it along with my mind tonight.
here ya go Eagle
Thanks Brian. I looked all over for that, I think my age is catching up to me.
Happy Holidays to you and your family.
Posted: Thu Dec 04, 2014 1:54 am
by Jimustanguitar
I tagged the STL with rostock, belt, clamp, carriage, and tricktrucks.... What other tags would make it easier to search for? Maybe tricktruck without an s and beltclamp/beltclamps?
Posted: Thu Dec 04, 2014 5:35 am
Jimustanguitar wrote:I tagged the STL with rostock, belt, clamp, carriage, and tricktrucks.... What other tags would make it easier to search for? Maybe tricktruck without an s and beltclamp/beltclamps?
Jim, I don't think adding more tags would make any difference. I usually can find whatever I need and I think my failure to find that belt clamp was just a senior moment.
Thanks for your attention to this but I really don't think you need to do anything.
Posted: Thu Dec 04, 2014 9:14 am
by BenTheRighteous
Eagle I'm not sure if you're aware but you can search a site straight from your browser with the following command: belt clamp site:repables.com
Maybe this link will help!!
http://lmgtfy.com/?q=belt+clamp+site%3Arepables.com
Just playing with you buddy. You know we all love you.
Posted: Thu Dec 04, 2014 9:59 am
by RegB
Posted: Thu Dec 04, 2014 10:49 am
by Jimustanguitar
Excellent point!
Print the belt clamps BEFORE you take apart your machine...
Some have reported that it works better that way
Posted: Sun Dec 07, 2014 8:33 am
by RegB
FYI, if anyone else had to take a short shipment of the 625 bearings.
Following an e-mail exchange ...OpenBuilds finally told me that the 625 bearings are back in stock, so I ordered the remaining 15 yesterday.
Too bad I couldn't get them ALL at the 15% Cyber Monday discount and all on the same shipping charge, but at a dollar each... I'll "suck it up".
{Pun alert} I'm bearing it.
Posted: Sun Dec 07, 2014 9:01 am
RegB wrote:FYI, if anyone else had to take a short shipment of the 625 bearings.
Love your Pun Alert!
Posted: Tue Dec 09, 2014 9:45 am
by RegB
Anyone else get their OpenBuilds parts and try fitting them together yet ?
I may be having a blonde/senior moment, but I had EXPECTED the eccentrics to fit inside the bearings.
Either they fit inside the truck plates or I have the wrong eccentrics.
My order SAYS 1/4 inch eccentrics, which is what Brian has spec'd in a few places.
6mm is the only alternative on their site.
