Page 4 of 5
				Re: The Ultimate Rostock Thing Collection
				Posted: Tue Aug 27, 2013 6:33 pm
				by krak
				krak wrote:I printed this out last week. The 40mm fan just came in. When the current print is finished I plan on installing this and the 25mm fan.
The 25 hour print finished late last night. Pretty good for a hobby level printer. Now I have the 25mm fan pointed at the hot end, and 40 mm fan duct installed. Which unit should be considered Fan 0 and Fan 1? Where do I need to be looking in the software to control Fan 1?
Oh and so far the fans seem to be pretty well balanced.
Edit: I started a new thread about fan questions to keep this thread a little cleaner.
http://forum.seemecnc.com/viewtopic.php?f=54&t=2485
				Posted: Wed Sep 04, 2013 9:41 pm
				by doctorgonzo
				How about a PWM-controlled solenoid powered by the shop compressor? Is that overkill? I mean, I could just stand around with a straw and blow. I really like the fan shroud, it will probably be one of the first things I print. Thanks.
-Doc
				Posted: Wed Sep 04, 2013 9:57 pm
				by edward
				doctorgonzo wrote:How about a PWM-controlled solenoid powered by the shop compressor? Is that overkill? I mean, I could just stand around with a straw and blow. I really like the fan shroud, it will probably be one of the first things I print. Thanks.
-Doc
I'm not sure if solenoids would like that high frequency operation, or if they could operate fast enough mechanically.  I only say this based on awareness of projects in both the hydraulic and automotive industries that are attempting to create PWM valves for "throttle-less" circuits.  In both cases I know of research efforts that spanned multiple years.
I'm sure it would certainly provide all the flow you need, though...
				Posted: Mon Sep 09, 2013 8:17 am
				by 626Pilot
				Rostock MAX Tower Alignment Brace
If you've ever done a tower alignment and thought, "This would be a lot easier if I had two or three friends to hold things very firmly in place," these clamps are for you. I got the idea from someone else on the forums, but I don't remember who it was.
				Posted: Thu Sep 12, 2013 9:57 am
				by MSURunner
				JohnStack wrote:
You printed the example out with a dual head? Can you go into that a bit somewhere?
Single head, just placed a bit of black filament in the bowden, followed by some orange and fed the black spool in later.
				Posted: Sat Oct 26, 2013 11:46 am
				by Mhagan
				I have been working on an enclosure for my Rostock Max. I noticed that a 12x24" sheet of acrylic fits rather nicely between the skates and really leaves a 1.75" gap on the top and bottom. This is really nice for me because I live in an apartment and using a panel saw to cut down a larger sheet in my living room would probably be frowned upon. The printer is with my wife right now doing a demonstration and I will post pictures as soon as she gets back. For now, you will all have to settle for the skeleton Thingiverse page.
http://www.thingiverse.com/thing:172116
				Posted: Sat Oct 26, 2013 2:34 pm
				by ccavanaugh
				Looking forward to seeing the end result.
I've been working on a design for a enclosed delta based around seemecnc parts. After calculating out print time on my old h1-1 to be over 120 hours, I cried uncle and just ordered a new Rostock MAX with the intention of adding an enclosure mod.
I'm trying to print in a garage at 50 F and want to keep the heat in.  I'm planning on adding a beaglebone or raspberry pi with a CO sensor as a safety device for unattended prints. The enclosure will aid in detection of the CO.
				Posted: Tue Jan 07, 2014 10:57 pm
				by cjdavis618
				Thought I would post my easy LED light ring.
http://www.thingiverse.com/thing:204581
Just used 2 sections from a 300smd 12volt led light strip and then glued it to the inside rim. Used Loctite's Go2 Glue and it has held up great for about 50 hours of printing in close proximity to the hotend. This is designed to work with the single hotend stock Rostock max. I have it wired to the fan so they both come on at once since I always run the peek fan at 100% anyway. Leaves 2mm of clearance from the rim to the print surface so no issues dragging parts or anything.
Uses factory screws and no modifications are needed.
[img]http://i5.photobucket.com/albums/y176/cjdavis618/rostock/DF3B9C64-2BD3-437A-B9DA-F7F0D0701F73_zpsyvqbg4ju.jpg[/img]
[img]http://i5.photobucket.com/albums/y176/cjdavis618/rostock/9B3CD5CB-6F49-4BBF-B152-6723FA25420D_zpspslhfpag.jpg[/img]
[img]http://i5.photobucket.com/albums/y176/cjdavis618/rostock/A6808902-C032-4824-9017-592CCE4CB5A0_zpsq5kl5zug.jpg[/img]
				Posted: Tue Jan 07, 2014 11:21 pm
				by int2str
				Posted: Wed Jan 08, 2014 8:20 am
				Neat and I added it to the collection, thanks!
				Posted: Wed Jan 08, 2014 9:13 am
				That is a very bright light.  Good job!
				Posted: Wed Jan 15, 2014 10:42 am
				by JolietDelta
				Aaand... here comes my humble contribution.
I've designed a dual extrution mount with integrated cooling. It is for use with the stock seemecnc hot ends.
http://www.thingiverse.com/thing:214536
Have fun. :-)
~Jens
				Posted: Wed Jan 15, 2014 11:02 am
				Added.
				Posted: Wed Jan 15, 2014 11:03 am
				JolietDelta wrote:Aaand... here comes my humble contribution.
Have fun.
~Jens
Your contribution is appreciated and can be very useful for the users who want to use the stock hot-ends in a dual mount configuration.
Thanks for contributing.
				Posted: Thu Jan 30, 2014 12:48 pm
				I've uploaded my
E3D - Bowden mounting adapter for the Rostock Max and added it to the collection.
				Posted: Fri Jan 31, 2014 3:21 pm
				I just completed these
Rostock Max Tool Caddies and uploaded them to Thingiverse. They are in the collection too.
				Posted: Fri Jan 31, 2014 3:24 pm
				by Batteau62
				Nice! and those zebra clips are da bomb!
				Posted: Fri Jan 31, 2014 3:30 pm
				Yeah, I love the zebra clips. The two back by the Onyx electrical connector are red.
				Posted: Fri Feb 07, 2014 7:11 am
				by Bill Havins
				mhackney,
Thanks for developing the collection!  Here is one to add:
http://www.thingiverse.com/thing:243270.  It is a very simple Dual Hotend Mounting.
I will report progress with dual hotends in this thread:
http://forum.seemecnc.com/viewtopic.php ... 885#p28885.
Bill
				Posted: Fri Feb 07, 2014 8:29 am
				Added it Bill, thanks.
				Posted: Sun Feb 09, 2014 4:31 am
				by bubbasnow
				i made a 40mm fan mount to be used with your e3d mount or any similar.  this acts as a 41mm spacer that leaves about 9mm of nozzle/platform clearance below.
				Posted: Sun Feb 09, 2014 6:45 am
				Thank you!  Which mount has this been tested with?
				Posted: Sun Feb 09, 2014 9:27 am
				That's "cool". I like the splitter back post.
cheers,
				Posted: Sun Feb 09, 2014 2:42 pm
				by bubbasnow
				Eaglezsoar wrote:Thank you!  Which mount has this been tested with?
The one Michael posted a few weeks ago, but im sure it would worth with pilots as well
				Posted: Mon Sep 01, 2014 11:32 am
				by DavidF
				Working on a new J head mount, this one is much better than my previous design. Thi one should be a direct bolt in without having to source screws or anything.
  I havent tried it yet, its printing now I will let you know how it comes out.
