Page 4 of 36
Re: E3D V4 All metal hotend
Posted: Thu Jul 18, 2013 10:44 pm
by Flateric
But correct me if I am wrong here but ferrofluids are prohibitively expensive. Also the heat still needs to then be removed from the ferrofluid and the fluid itself is also fairly weighty (heavy) so to include a support system to remove the heat before the fluid could be recycled, further adding more weight to the effector would be counter productive. Especially since we all in the delta world are, or really should be trying to make the entire effector and it cargo as lightweight as reasonably possible.
Posted: Sat Jul 27, 2013 7:59 pm
by Flateric
Well I feel the heat issues with the E3D hotend have been greatly reduced and addressed by E3D relating to PLA.
[img]
http://i.imgur.com/CvFIh9N.jpg[/img]
The heat range before jamming is not as large as a jhead for instance, but it is no longer razor sharp, meaning it used to be a couple degrees high and it was a prob, a couple degrees low and it was a different prob. I find the butter zone for PLA on the E3D to be between 175 and no higher than 200. This is a general overall number and not specific to any type of PLA in particular, which will obviously have specifics. But for me I start at 180 and go from there. I have to have more and stronger reasons for each 5c I go up. Meaning that last 195 to 200 needs a damn good reason because I do not like going that close to a plugged hotend.
So there you go. If these guys can manage to nail down their shipping to reasonable times then they should be shovelling one of these off to nearly everyone in my opinion.
Posted: Sat Jul 27, 2013 8:17 pm
by Batteau62
Flateric,(and othere3d owners) do you use the OEM thermistor, or the screw in one that is so popular? I'm building mine now. I'm looking for the best temp control like we all do
Posted: Sat Jul 27, 2013 9:39 pm
by cpunches
Personally I use a screw in thermistor on the E3d and the stock hot-end. I had a terrible time trying to get the ones I used RTV, or kapton tape, to affix to the hotend to stay put. Also it's a lot easier for me to remove them if I want to move the same thermistor to a new hotend.
Posted: Sun Jul 28, 2013 12:01 am
by Generic Default
Did anyone else have problems with them shipping it? Sanjay told me he shipped my hotend on July 23rd and that I would get an automated email with the tracking number shortly, but now four days later I still haven't gotten the tracking number and I think he lied to me about shipping it.
EDIT:
Nevermind, he shipped it on the 23rd and the tracking number was just delayed from error. Problem solved, ignore this post.
Posted: Sun Jul 28, 2013 12:07 am
by cpunches
I've purchased two E3d hotends as well as some misc. parts. In my experience Sanjay and David have gone out of their way to make sure I (and others) am a satisfied customer. It does take a while to get the items from the UK to the US. I always got a reply from them whenever I had a problem and communicated with them via email as well as this forum and G+.
Generic Default wrote:Did anyone else have problems with them shipping it? Sanjay told me he shipped my hotend on July 23rd and that I would get an automated email with the tracking number shortly, but now four days later I still haven't gotten the tracking number and I think he lied to me about shipping it.
Posted: Sun Jul 28, 2013 2:13 am
by Flateric
cpunches wrote:Personally I use a screw in thermistor on the E3d and the stock hot-end. I had a terrible time trying to get the ones I used RTV, or kapton tape, to affix to the hotend to stay put. Also it's a lot easier for me to remove them if I want to move the same thermistor to a new hotend.
I agree with this as well. However it is possible to easily make your own threaded thermistor. Just use the little brass bit from the back of any spare computer related product you may have kicking around (modems, routers, old video cards, old motherboards, anything with a db9 serial port, vga port, etc)
Either use JBweld and simply weld the thermistor into the female side, or use fire cement, or high temp epoxy. Thread the hole and your set.
And also yes, I would also agree they have been putting in a huge effort and seem to be full 100% committed to customers and service. I think the initial issue were simply a case of "OMG demand is far outstripping our expectations" and being caught in the position of having to play catchup.
I'm going to bet that they are by far the most popular all metal hotend on the market. A very good position to be in, but one that I don't think they fully realized at first they would be in so quickly. This is a real compliment to their product and design and confirmed by the market speaking with it's wallet.
Clearly congratulations guys! But you have to sustain it long term which I have no doubts anymore you will.
Posted: Sun Jul 28, 2013 2:23 am
by thenewguy
What are you entering in for the settings on kiss.
Hotend came with a .45 nozzle so enter that in kiss for nozzle size or would .50 work better and what about layer height? .2?
Also the same question for the .25 nozzle which I also purchased. But yet had time to play with.
Posted: Sun Jul 28, 2013 2:40 am
by Flateric
Be careful with that .25 nozzle, it is very difficult to dial in correctly especially with PLA of any type. The tip is so small that it easily backs the filament up while allowing it to swell in the hotend and jam. Far far less of an issue with ABS and most other types of filament. I can honestly say I have fed every single type of filament currently on the market through mine.
I'll check the settings for you in the morning. But I am certain my layer height was .2, temp was 190 and print speed was decently high.
Posted: Sun Jul 28, 2013 6:03 am
by thenewguy
Flateric wrote:Be careful with that .25 nozzle, it is very difficult to dial in correctly especially with PLA of any type. The tip is so small that it easily backs the filament up while allowing it to swell in the hotend and jam. Far far less of an issue with ABS and most other types of filament. I can honestly say I have fed every single type of filament currently on the market through mine.
Working nights also? Haha
I put .45 in for nozzle size and nozzle fill? I think also had .2 for layer height. I got really good prints once I did a few adjustments. I upgraded the extruder, hot end, and arms at the same time. Huge difference. Then using kiss on top of that was sweet.
So I have good prints but was woundering what other people used for settings.
Btw I only use abs for now.
Posted: Sun Jul 28, 2013 4:21 pm
by lordbinky
I just dialed my extruder settings for Kisslicer in. I ended up with .44 extrusion width .2 layer height. For this particular filament (JET - gray ABS) my filament settings were 1.73 mm diameter (average measured) and .86 flow tweak which resulted in single wall widths of .45 +/-.02 . For reference how sensitive that flow tweak setting is, a flow tweak of .85 resulted in .4 mm +/- .03. Working on getting infill tweaked now.
Posted: Mon Jul 29, 2013 3:44 am
by 626Pilot
I was thinking of getting an E3D, unless Trick Laser gets their hotend done sometime soon, but this makes me wonder. I have been printing with a .35mm nozzle on a Budaschnozzle and I have to say it's been fantastic. I didn't see that diameter available on the E3D, and I don't want to use a .5 nozzle because it's not as fine and definitely a lot more drooly than .35.
Posted: Mon Jul 29, 2013 7:55 am
by Broose
Flateric wrote:Well I feel the heat issues with the E3D hotend have been greatly reduced and addressed by E3D relating to PLA.
Flateric- Did you recently get a newer version of their hotend that has the improved performance? I purchased mine in April and it has the tight temp range issues with PLA you discussed.
Posted: Mon Jul 29, 2013 1:07 pm
by Flateric
Ya, mine is a updated recent version. Arrived end of June. I had given up trying to use PLA with the older version. It was just far too easy to plug it up. The newer one is dramatically improved. I felt like the older one had a 10-15c range of use with PLA. Anything outside of that was asking for trouble.
The new one is still not as forgiving as a stock hotend or jhead, but very useable and very forgiving overall. Temp range is more like 30c give or take as long as you do not exceed 205c. Different PLA's will vary of course. I use seemecnc or ultimachine PLA which is of generally very high quality.
Posted: Tue Jul 30, 2013 1:44 pm
by SanjayM
Generic Default
No lies, just a lost piece of paper and a bit of confusion between me and my shipping guy - I emailed you a little while ago with the tracking number, which you will see has a shipping date of the 23rd. (If you are who I think you are that is)
Flateric
Cheers for the kind words, it means a lot to us. Initially the issue with shipping vs demand was indeed a "OMG demand > expected" one, but since May/June it's consistently been a supply issue. It's always the electronic bits, be it fans, or heaters (which we are waiting on now), or thermistors. The machined metal parts are produced by a guy down the road, we can go over and hassle him if the parts don't turn up. When China sends your stuff 6 weeks late, you don't have much of a way to sort that out. I have everything I need in stock to ship over a thousand units in the room behind me right now, but I don't have a single decent heater cartridge. A new factory in China has been pumping out very low quality heater units that are way below power and not the right mechanical size/tolerance. Because they're cheaper they have flooded the market, and getting good ones is nearly impossible. We've sent back over 500 units and not shipped product because we refuse to ship crap. I tell myself it's worth it - but seeing what some others get away with shipping I think maybe i'm being fussy!
I'd definitely like to use a threaded thermistor, but there are issues with getting them in quantities we need rated to 300C. Thinking of going self-manufacture on them once I get some employees sorted and can sell them as a "thing" in their own right.
626Pilot
Our standard nozzle is a 0.4mm job, which is really negligibly different from a 0.35. I think you'll find the E3Dv5 is one of the least dribbly nozzles out there, getting the orifice diameter to length ratio just right is key for this.
Posted: Tue Jul 30, 2013 2:56 pm
by bvandiepenbos
626Pilot wrote:Flateric wrote:Be careful with that .25 nozzle, it is very difficult to dial in correctly especially with PLA of any type. The tip is so small that it easily backs the filament up while allowing it to swell in the hotend and jam. Far far less of an issue with ABS and most other types of filament. I can honestly say I have fed every single type of filament currently on the market through mine.
Getting closer on the TL hot end, just need more hours in the day! Fins are designed and machined as well as most everything else, just need to get tooling designed and made for the "nozzle"
That E3D is a really nicely made piece. Great job guys.
Kind of strange to see... very much like what I have been working on, other than the nozzle design.
If my nozzle idea does not work out I will likely just go with the E3D myself.
Although I am very pleased with the J-head from hotends.com I have been running.
Posted: Tue Jul 30, 2013 5:19 pm
by lordbinky
I bought a couple heater cartridges from various places, so I don't remember who had the bad one, but I currently have a bad one in the hot end until I get a replacement. I was awesome and destroyed my working one, which was fine thinking I had another backup. It's possible it was a 24V 40W instead of a 12V 40W as well. Either way, right now my hotend heats up ridiculously slow, and can't break 231°C .
Posted: Tue Jul 30, 2013 9:18 pm
by Generic Default
Thanks Sanjay! The tracking number is working and I should hopefully have my hotend by the end of this week. I'm looking forward to testing this with some higher temperature plastics once I make a filament extruder, but until then I'll just use nylon at higher temperatures to get strong parts. The trimmer line I've been printing is extremely strong across layers (strong enough to permanently bend a steel pick), but delaminates easily when printed below 240 C (which is the hottest I can print without a full metal hotend). The E3d should allow me to make more solid mechanical parts.
Sorry for accusing you of lying earlier, I'm just used to some companies who send out fake tracking numbers and tell the customers stuff has shipped when it hasn't. You shipped my hotend a full week ahead of the preorder deadline, which is faster than I was expecting. So thank you, and I'll probably be buying more of your stuff in the future!
Posted: Wed Jul 31, 2013 9:04 am
by Fiero2M6
I finally got my E3D V5 hotend installed. It's awesome! Much less ooze with PLA and no worries about high temperature with nylon.
This is by far the best upgrade I've ever done. You can tell a lot of time was spent making it perfect.
Sanjay: Do you have an optimum layer width to thickness ratio for the 0.4mm nozzle?
Posted: Wed Jul 31, 2013 10:20 am
Fiero2M6 wrote:I finally got my E3D V5 hotend installed. It's awesome! Much less ooze with PLA and no worries about high temperature with nylon.
Just wondering, do you know what the difference is between your version 5 and the older version 4.1?
Documentation on the site is sparse and I am still trying to figure out what the difference is.
Posted: Wed Jul 31, 2013 1:07 pm
by Fiero2M6
I'm not exactly sure. I only have version 5. Its supposed to have many tweaks and be slight lighter, but I do not know the specifics. It's supposed to have the same exterior dimensions.
The biggest change I can see is in the nozzle angle:
http://e3d-online.com/downloads.html
I think the steep taper on the new nozzle allows the "hot spot" on the printed part to be smaller. This allows more cooling air flow, and prevents curling overhangs. You might consider upgrading to the new nozzle design if you have a previous version. My overhang performance with PLA has improved dramatically.
Posted: Wed Jul 31, 2013 2:19 pm
Fiero2M6 wrote:I'm not exactly sure. I only have version 5. Its supposed to have many tweaks and be slight lighter, but I do not know the specifics. It's supposed to have the same exterior dimensions.
I would like to order a new nozzle but I have the version 4 hotend and the nozzles that they have online for purchase say they are for the version 4. If I order one I don't know if it
would be one like you have or the older type like I have. The website has very little to say or sell for the version 5 and they are so busy that they don't have the time to upgrade the
website to reflect parts for version 5. I will wait until they change the site so that I know exactly what I am ordering. On the download page I don't see anything that shows the differences between version 4 and 5. They should also change the name from the download page to the viewing page, downloads require a login that I don't have and I do not intend
to get. I am happy that yours work well for you.
Posted: Wed Jul 31, 2013 4:02 pm
by 626Pilot
Do I need to get the Bowden version of this or can I get the regular one? I don't really need to pay for more PTFE tubing or push-to-connect fittings.
Posted: Wed Jul 31, 2013 4:32 pm
One other question then I won't bother you again, I promise.
Did the version 5 you received come tapped for a PTC on the top?
Posted: Wed Jul 31, 2013 4:48 pm
626Pilot wrote:Do I need to get the Bowden version of this or can I get the regular one? I don't really need to pay for more PTFE tubing or push-to-connect fittings.
You don't have to buy the bowden (expensive) one. You can use a mounting that you can print at this link:
http://www.thingiverse.com/thing:57889
Cambo3D is also selling aluminum ones at the Seeme's List sub-forum.
