Protip: Don't forget to adjust your thermistor values
Posted: Mon Mar 28, 2016 8:36 pm
by bob64
Use this for the e3d v6 hotend thermistor:
M305 P1 T100000 B4388 R4700 H30 L0
Was wondering why the extruder was having a hard time pushing filament... turns out the sensor temperature was reading higher then it was.
As for the bed:
M305 P0 T100000 B4286 R4700 H30 L0
This optimizes it slightly for the lower bed temps.
Re: Protip: Don't forget to adjust your thermistor values
Posted: Mon Mar 28, 2016 11:09 pm
by bot
I experience the exact same thing.
Posted: Mon Mar 28, 2016 11:12 pm
by 3D-Print
What is the best and inexpensive way to measure real temp?
Posted: Tue Mar 29, 2016 10:12 am
by bob64
Get a thermocouple from ebay or something. Either way, if you've got a similar thermistor, the settings above should work.
Posted: Tue Mar 29, 2016 12:59 pm
by Great_Thark
In theory E3D V6 should be the same settings as stock hotend. They have same thermistor according to specs.
