Prometheus V2 adjustable layer fans?
Posted: Thu Jul 21, 2016 6:40 am
So I've now got two Prometheus V2 hot ends with two different nozzles so that I can easily swap between them on my Metal Max. I installed my 0.4mm hotend earlier in place of the 0.6mm, and the 3 layer fans sit lower than the 0.4mm nozzle
(the 0.4mm configuration has a smaller melt zone and the nozzle sits a bit higher). I'm trying to figure out an easy solution for also swapping between layer fan heights. Is there an adjustable fan mount or something out there?
I'm also using a 713maker hotend mount.
If it helps, here is an album that shows everything in case I didn't clearly describe my platform/hotend/mount situation. http://imgur.com/a/qw1Jn
