Y Tower Calibration Issue
Posted: Mon Aug 22, 2016 9:29 pm
Hi all
After upgrading arms, effector platform, hot-end and carriages I am having some calibration issues. I can get things going well enough to print good with small diameter items - but it goes bad when I move to larger items.
I think the problem is related to the DELTA_RADIUS and related settings, which I admit I don't understand very well. If I reset and start my calibrations steps from scratch (set Z-height, and then run the Tower Calibration macros in MatterControl) the X and Z towers are very close, but the Y tower is well over 5mm too high. I can correct this with the end-stop screw, but this variation seems way too high.
Is there a good article that can explain these settings in detail so I can troubleshoot?
