Automatic Nozzle Brush for V3
Posted: Sun Nov 20, 2016 8:18 pm
by timskloss
My daughter does not like to pick off the ooze from the nozzle just before our new Rostock Max V3 begins to print. So I saw an opportunity and sketched up a part to hold a small wire brush to automatically clean the nozzle when starting a print.
I put the thing here: http://www.thingiverse.com/thing:1904416
The g-code to add to your slicer is listed in the description of the thing. The only drawback is that you need to remove the brush after starting a large diameter print. For most smaller prints it can just stay in place.
For such a simple thing, it works quite well and has really cut down on stray filaments interfering with the first layer.
Re: Automatic Nozzle Brush for V3
Posted: Sun Nov 20, 2016 9:43 pm
The link is broken.
Posted: Sun Nov 20, 2016 10:54 pm
by timskloss
Thanks for the tip. It is my first time to publish a thing and I forgot to hit the 'publish' button. It should work now.
Posted: Mon Nov 21, 2016 10:48 am
Be careful with your GCode to wipe the nozzle! I've read more than one horror story of someone getting a little over eager on "brush depth" and shorting out their heater or LCD :)
Posted: Tue Nov 22, 2016 7:33 pm
by timskloss
Jimustanguitar wrote:Be careful with your GCode to wipe the nozzle! I've read more than one horror story of someone getting a little over eager on "brush depth" and shorting out their heater or LCD :)
Oh yes, I see you could short out the heater leads with the metal brush bristles if you lowered the nozzle too much!
Posted: Tue Nov 22, 2016 10:04 pm
Maybe make yourself a little brush out of a block of PTFE.
Posted: Wed Nov 23, 2016 1:35 am
by Xenocrates
geneb wrote:Maybe make yourself a little brush out of a block of PTFE.
I was thinking more a refractory ceramic fiber would be a good idea (I should try this on one of the Taz's. That way it's not my printer if it breaks something). Although it would mean that anything but a steel hotend might be abraded faster, and the fibers might detach or do unfun things over time.
Posted: Wed Nov 23, 2016 3:01 am
by DeltaCon
Nice idea. Will have to adapt to V2 bed when I get my printer working again...
