Page 1 of 5
The Ultimate Rostock Thing Collection
Posted: Wed Feb 13, 2013 9:51 am
A collection dedicated to the Rostock:
The Ultimate Rostock Printer Thing Collection!
Cheers,
Re: The Ultimate Rostock Thing Collection
Posted: Thu Feb 14, 2013 11:50 am
Thanks for this and all your great posts!
Posted: Thu Feb 14, 2013 5:01 pm
by Highcooley
A new thing for the collection:
http://www.thingiverse.com/thing:50505
Looking forward to get some feedback if it helps.
Cheers,
Andy
Posted: Thu Feb 14, 2013 5:38 pm
by barnett
I was going to so that same thing (at some point) because it seemed like the ultimate test of the level bed. Nice!
thanks!
Posted: Thu Feb 14, 2013 5:46 pm
Thanks, I added it and that is very cool! I'll be printing this as soon as I get a new glass build plate.
So, it looks like one should set layer thickness to .30mm in their slicer?
Posted: Thu Feb 14, 2013 7:22 pm
by Highcooley
mhackney wrote:Thanks, I added it and that is very cool! I'll be printing this as soon as I get a new glass build plate.
Haven't tried what happens with 0.2mm but yes...I think 0.3 mm leaves a little bit of head room for uneven beds.
I just measured my bed again and figured out, that it is slightly bent upwards to the Z columnd because I ahevn't got paper clips there... need to correct that.
Posted: Thu Feb 14, 2013 7:26 pm
Thanks. Do you have a glass or borosilicate surface?
Regards,
Posted: Fri Feb 15, 2013 5:43 am
by Highcooley
mhackney wrote:Thanks. Do you have a glass or borosilicate surface?
Regards,
I've got a borosilicate plate. As described, I've got 5 paperclips along the edges, all between two of the screws holding the bed to the printer. Except at the top side, where the leads are soldered to the board. If I measure close to all three columns, as well as their "negatives" (e.g. X -112.6/-65 and -112.6/65), I see that the glass plate is bent from center to the Z column. Or, as I leveled Z at the three columns, the X and Y negatives are far below zero. I probably need to attach more clips on one or both sides of the soldering pads.
Posted: Fri Feb 22, 2013 3:05 pm
@Highcooley - I have tried printing your calibration thing and some weird stuff is happening! After it prints the large circle first (2 wide) it then prints these odd dashes where the smaller circle is, then prints some other areas and comes back and fills in those dashes. The dashes are causing all sorts of headaches. I suspect this may be a slicing issue. What app and what parameters did you use to slice yours?
cheers,
Posted: Fri Feb 22, 2013 3:15 pm
I see from the gcode what is happening:
Do you have a smaller nozzle perchance? Mine is .5mm.
Posted: Fri Feb 22, 2013 3:24 pm
Odder yet - that feature does not appear in your STL file! Your file clearly has 2 rings - a larger one and one about 1/2 to the center. My sliced version is printing 3 rings. The larger one you see here and another about 1cm inside that. Then the smaller ring. That smaller ring may also have another inset ring but I have stopped the print before it gets that far. Vary odd slicing issue. The radial line you see coming from X should go all the way to the outermost ring but it stops at the phantom inner ring!
Posted: Fri Feb 22, 2013 5:17 pm
Ok, I figured part of this out! The outermost circle is a perimeter not the part! If I don't explicitly set extrusion widths (to .55mm) and let slic3r calculate them (.70mm) then the circles are generated as a continuous bead and not broken up into the "dashes". I think I can print it now.
Posted: Mon Feb 25, 2013 5:14 am
by Highcooley
mhackney wrote:Ok, I figured part of this out! The outermost circle is a perimeter not the part! If I don't explicitly set extrusion widths (to .55mm) and let slic3r calculate them (.70mm) then the circles are generated as a continuous bead and not broken up into the "dashes". I think I can print it now.
Sorry for my late reply. I was off during weekend. I sliced with slic3r, having set the nozzle to 0.5mm. I would have to check, if I set 0.55mm as the extrusion width. Anyway, I didn't have these dashes. But something other was a bit strange. Instead of printing continuous outlines one after the other, the perimeters where split up to different sections and the letters where printed separately. Although I checked the design twice, that the different parts should be merged into one single part, this somehow doesn't seem to be the case. Maybe netfabb would help. But I haven't tried it yet.
Posted: Sun Mar 10, 2013 10:43 pm
by Av8r RC
I bought some filament from RainBot this weekend. Since thier spools are wider than the ones from seemecnc or Protoparadigm (the only two spools I've ever had), I designed a kit to widen the spool holder.
http://www.thingiverse.com/thing:60322
There are three different versions of the extensions. A single extension (you'll need to print two), a pair of extensions, or a set of small spacers to use instead of the big extensions.
Posted: Sun Mar 10, 2013 10:47 pm
Great, thanks! I've added it to the collection.
Cheers,
Posted: Mon Mar 11, 2013 7:45 pm
by Av8r RC
Mhackney, thanks for adding it to the collection. Here's a pic of the kit installed.
Posted: Mon Mar 11, 2013 7:50 pm
Cool. I am going to print it tonight to use with my new Add-A-Struder that is due to arrive tomorrow!
FYI - RichRap (the one an only) uploaded some Rostock things today that I added to the collection - a JHead adapter and an extruder.
Posted: Mon Mar 11, 2013 7:56 pm
@Av8r RC - the new spool rod and clip you made would be another great addition resized to the original extruder arm. Just say'n is all! (hint, hint)
Posted: Mon Mar 11, 2013 8:17 pm
by Av8r RC
Posted: Mon Mar 11, 2013 8:20 pm
That was quick! Thanks, added to the collection. I'll print one of these too, I don't like that flat melamine spindle.
Posted: Tue Mar 12, 2013 11:48 am
Posted: Tue Mar 12, 2013 12:02 pm
by cambo3d
looks good!
Posted: Tue Mar 12, 2013 1:40 pm
It works great too! I love the little clip that holds it in place.
I have the full extension set printing now. My add a struder kit is due to arrive today and I received my Rainbot filament today. I now know what this extension is all about, those are WIDE spools!
Posted: Tue Mar 12, 2013 3:51 pm
@AV8r RC - I really love the way the filament spools roll smoothly off this Spool Rod! Nice upgrade. I used to have to baby-sit the filament spool to make sure it didn't get stuck, no longer with this. I am printing the extended set in black ABS to compliment my white Add-A-Struder kit!
Posted: Tue Mar 12, 2013 5:50 pm
by Av8r RC
Yeah those spools are pretty wide. I'm glad it's working good for you.
I'm working on a fan duct right now. The one Highcooley posted will not work with the new nozzle.
