Print quality woes
Posted: Mon Dec 04, 2017 7:22 am
				Hello all. Just recently upgraded my rostock max v2 with a titan aero , pei bed and ballcup arms. My prints thus far have improved but I'm stilling having a issue with 1 corner lifting on abs and corners not as sharp as they should be. Also there seems to be slight ringing. Can anyone chime in on trying to troubleshoot this.  I tried lowering jerk to 30 and increasing acceleration to 2000
I sanded the bed with 400 grit and cleaned with alcohol. and ran bed at 90 this helped somewhat. Printing at 220 abs .6 nozzle
Using slic3r prusa edition all advanced settings are set to default but first layer set to 140%
here is a snippet of gcode and eprm
; generated by Slic3r 1.36.2-prusa3d-win64 on 2017-12-03 at 21:53:23
; external perimeters extrusion width = 0.68mm
; perimeters extrusion width = 0.68mm
; infill extrusion width = 0.68mm
; solid infill extrusion width = 0.68mm
; top infill extrusion width = 0.60mm
; support material extrusion width = 0.40mm
; first layer extrusion width = 0.35mm
; avoid_crossing_perimeters = 1
; bed_shape = 139.233x14.634,136.941x29.1076,133.148x43.2624,127.896x56.9431,121.244x70,113.262x82.2899,104.04x93.6783,93.6783x104.04,82.2899x113.262,70x121.244,56.9431x127.896,43.2624x133.148,29.1076x136.941,14.634x139.233,0x140,-14.634x139.233,-29.1076x136.941,-43.2624x133.148,-56.9431x127.896,-70x121.244,-82.2899x113.262,-93.6783x104.04,-104.04x93.6783,-113.262x82.2899,-121.244x70,-127.896x56.9431,-133.148x43.2624,-136.941x29.1076,-139.233x14.634,-140x0,-139.233x-14.634,-136.941x-29.1076,-133.148x-43.2624,-127.896x-56.9431,-121.244x-70,-113.262x-82.2899,-104.04x-93.6783,-93.6783x-104.04,-82.2899x-113.262,-70x-121.244,-56.9431x-127.896,-43.2624x-133.148,-29.1076x-136.941,-14.634x-139.233,0x-140,14.634x-139.233,29.1076x-136.941,43.2624x-133.148,56.9431x-127.896,70x-121.244,82.2899x-113.262,93.6783x-104.04,104.04x-93.6783,113.262x-82.2899,121.244x-70,127.896x-56.9431,133.148x-43.2624,136.941x-29.1076,139.233x-14.634,140x0
; bed_temperature = 90
; before_layer_gcode =
; bridge_acceleration = 0
; bridge_fan_speed = 100
; brim_width = 0
; complete_objects = 0
; cooling = 1
; default_acceleration = 0
; deretract_speed = 0
; disable_fan_first_layers = 12
; duplicate_distance = 6
; end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
; end_gcode = M104 S0 ; turn off temperature\nM140 S0 ; turn off bed temperature\nG91\nG1 Z10 E-5. F18000\nG90\nG28 ; home X axis\nM84     ; disable motors\n; BEGINNING OF PRINT FINISHED TONES\nM117 PRINT FINISHED\nM120 S6 P10\nG4 P40\nM117 WAIT UNTIL COOL\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\nM120 S6 P10\nG4 P40\n; END OF PRINT FINISHED TONES
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_colour = ""
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 0
; fan_below_layer_time = 60
; filament_colour = #FFFFFF
; filament_cost = 0
; filament_density = 0
; filament_diameter = 1.75
; filament_max_volumetric_speed = 0
; filament_notes = ""
; filament_soluble = 0
; filament_type = ABS
; first_layer_acceleration = 0
; first_layer_bed_temperature = 84
; first_layer_extrusion_width = 140%
; first_layer_speed = 40
; first_layer_temperature = 220
; gcode_comments = 1
; gcode_flavor = repetier
; infill_acceleration = 0
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; max_layer_height = 0.45
; max_print_speed = 90
; max_volumetric_extrusion_rate_slope_negative = 0
; max_volumetric_extrusion_rate_slope_positive = 0
; max_volumetric_speed = 0
; min_fan_speed = 30
; min_layer_height = 0.07
; min_print_speed = 10
; min_skirt_length = 10
; notes =
; nozzle_diameter = 0.6
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 0
; post_process =
; printer_notes =
; resolution = 0
; retract_before_travel = 2
; retract_before_wipe = 0%
; retract_layer_change = 0
; retract_length = 1
; retract_length_toolchange = 10
; retract_lift = 0.7
; retract_lift_above = 0
; retract_lift_below = 0
; retract_restart_extra = 0.1
; retract_restart_extra_toolchange = 0
; retract_speed = 40
; single_extruder_multi_material = 0
; skirt_distance = 8
; skirt_height = 1
; skirts = 4
; slowdown_below_layer_time = 5
; spiral_vase = 0
; standby_temperature_delta = -5
; start_filament_gcode = "; Filament gcode\n"
; start_gcode = G28\nM104 S[first_layer_temperature]\nM190 S[first_layer_bed_temperature]\nM109 S[first_layer_temperature]\n; BEGINNING OF HEAD MOVEMENT WARNING TONES\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM120 S4 P10\nG4 P40\nM117 KEEP HANDS AWAY\nG4 S3\n; END OF HEAD WARNING TONES
; temperature = 220
; threads = 5
; toolchange_gcode =
; travel_speed = 240
; use_firmware_retraction = 0
; use_relative_e_distances = 1
; use_volumetric_e = 0
; variable_layer_height = 1
; wipe = 0
; wipe_tower = 0
; wipe_tower_per_color_wipe = 15
; wipe_tower_width = 60
; wipe_tower_x = 180
; wipe_tower_y = 140
; z_offset = 0
; clip_multipart_objects = 0
; dont_support_bridges = 0
; elefant_foot_compensation = 0.7
; extrusion_width = 0
; first_layer_height = 0.28
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.25
; raft_layers = 0
; seam_position = nearest
; support_material = 1
; support_material_angle = 45
; support_material_buildplate_only = 1
; support_material_contact_distance = 0.24
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0.4
; support_material_interface_contact_loops = 0
; support_material_interface_extruder = 1
; support_material_interface_layers = 5
; support_material_interface_spacing = 1
; support_material_interface_speed = 100%
; support_material_pattern = honeycomb
; support_material_spacing = 3
; support_material_speed = 30
; support_material_synchronize_layers = 0
; support_material_threshold = 0
; support_material_with_sheath = 0
; support_material_xy_spacing = 50%
; xy_size_compensation = 0
; bottom_solid_layers = 3
; bridge_flow_ratio = 1
; bridge_speed = 60
; ensure_vertical_shell_thickness = 0
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0
; external_perimeter_speed = 40
; external_perimeters_first = 0
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 30%
; fill_pattern = rectilinear
; gap_fill_speed = 30
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_overlap = 15%
; infill_speed = 40
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 60
; perimeters = 3
; small_perimeter_speed = 40
; solid_infill_below_area = 70
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0
; solid_infill_speed = 50
; thin_walls = 0
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 50
; top_solid_layers = 5
06:14:27.414 : EPR:2 75 250000 Baudrate
06:14:27.424 : EPR:1 43 1 Advanced User
06:14:27.429 : EPR:3 129 4663.449 Filament printed [m]
06:14:27.433 : EPR:2 125 1803864 Printer active [s]
06:14:27.433 : EPR:2 79 1800000 Max. inactive time [ms,0=off]
06:14:27.448 : EPR:2 83 0 Stop stepper after inactivity [ms,0=off]
06:14:27.464 : EPR:3 11 80.0000 Steps per mm
06:14:27.464 : EPR:3 23 300.000 Max. feedrate [mm/s]
06:14:27.464 : EPR:3 35 120.000 Homing feedrate [mm/s]
06:14:27.480 : EPR:3 39 30.000 Max. jerk [mm/s]
06:14:27.480 : EPR:3 133 0.000 X home pos [mm]
06:14:27.507 : EPR:3 137 0.000 Y home pos [mm]
06:14:27.513 : EPR:3 141 0.000 Z home pos [mm]
06:14:27.524 : EPR:3 145 250.000 X max length [mm]
06:14:27.529 : EPR:3 149 250.000 Y max length [mm]
06:14:27.532 : EPR:3 153 293.425 Z max length [mm]
06:14:27.532 : EPR:3 59 2000.000 Acceleration [mm/s^2]
06:14:27.548 : EPR:3 71 3000.000 Travel acceleration [mm/s^2]
06:14:27.548 : EPR:3 881 290.800 Diagonal rod length [mm]
06:14:27.564 : EPR:3 885 144.000 Horizontal rod radius at 0,0 [mm]
06:14:27.564 : EPR:3 925 145.000 Max printable radius [mm]
06:14:27.579 : EPR:1 891 80 Segments/s for travel
06:14:27.579 : EPR:1 889 225 Segments/s for printing
06:14:27.606 : EPR:1 893 0 Tower X endstop offset [steps]
06:14:27.612 : EPR:1 895 0 Tower Y endstop offset [steps]
06:14:27.624 : EPR:1 897 0 Tower Z endstop offset [steps]
06:14:27.632 : EPR:3 901 210.000 Alpha A(210):
06:14:27.632 : EPR:3 905 330.000 Alpha B(330):
06:14:27.647 : EPR:3 909 90.000 Alpha C(90):
06:14:27.647 : EPR:3 913 0.000 Delta Radius A(0):
06:14:27.663 : EPR:3 917 0.000 Delta Radius B(0):
06:14:27.663 : EPR:3 921 0.000 Delta Radius C(0):
06:14:27.679 : EPR:3 933 0.000 Corr. diagonal A [mm]
06:14:27.679 : EPR:3 937 0.000 Corr. diagonal B [mm]
06:14:27.699 : EPR:3 941 0.000 Corr. diagonal C [mm]
06:14:27.708 : EPR:0 106 1 Bed Heat Manager [0-3]
06:14:27.715 : EPR:0 107 200 Bed PID drive max
06:14:27.725 : EPR:0 124 80 Bed PID drive min
06:14:27.730 : EPR:3 108 74.410 Bed PID P-gain
06:14:27.733 : EPR:3 112 1.510 Bed PID I-gain
06:14:27.733 : EPR:3 116 919.520 Bed PID D-gain
06:14:27.749 : EPR:0 120 200 Bed PID max value [0-255]
06:14:27.749 : EPR:3 200 837.000 Extr.1 steps per mm
06:14:27.749 : EPR:3 204 60.000 Extr.1 max. feedrate [mm/s]
06:14:27.764 : EPR:3 208 30.000 Extr.1 start feedrate [mm/s]
06:14:27.764 : EPR:3 212 6500.000 Extr.1 acceleration [mm/s^2]
06:14:27.764 : EPR:0 216 3 Extr.1 heat manager [0-3]
06:14:27.780 : EPR:0 217 205 Extr.1 PID drive max
06:14:27.780 : EPR:0 245 60 Extr.1 PID drive min
06:14:27.806 : EPR:3 218 9.1900 Extr.1 PID P-gain/dead-time
06:14:27.811 : EPR:3 222 0.6400 Extr.1 PID I-gain
06:14:27.821 : EPR:3 226 32.8600 Extr.1 PID D-gain
06:14:27.826 : EPR:0 230 255 Extr.1 PID max value [0-255]
06:14:27.834 : EPR:2 231 0 Extr.1 X-offset [steps]
06:14:27.834 : EPR:2 235 0 Extr.1 Y-offset [steps]
06:14:27.834 : EPR:1 239 3 Extr.1 temp. stabilize time [s]
06:14:27.850 : EPR:1 250 150 Extr.1 temp. for retraction when heating [C]
06:14:27.850 : EPR:1 252 0 Extr.1 distance to retract when heating [mm]
06:14:27.850 : EPR:0 254 255 Extr.1 extruder cooler speed [0-255]
06:14:27.865 : EPR:3 246 0.000 Extr.1 advance L [0=off]
