Printing in air
Posted: Sat Feb 24, 2018 3:47 pm
I was wondering if anyone has had this issue. My rostock max v2 will, sometimes at the start of a print, and sometimes randomly at any point during a print, raise up several inches and off to the side printing off the bed into nothing. At first i thought it was the size of the prints i was trying (i have done others of this size in the past) but it happened during another print that was at least several inches away from the white border lines.
Also when using the macros to manually calibrate the machine for each tower, after going to the z tower point and then homing it, when the screw hits the limit switch it jitters up and down real fast before reaching its home position, instead of hitting it once and moving down like it should. But homing from the other two macro tower points do not cause the same sound and movement issue. I am unsure if these two things are related.
Thanks for any help with this.
