Time lapse video!
Posted: Wed Mar 13, 2013 11:53 pm
Check this out:
http://youtu.be/J1-TyeIX-KI
One frame every 30 seconds.
\o/
Re: Time lapse video!
Posted: Thu Mar 14, 2013 12:09 am
by cambo3d
nice
Posted: Thu Mar 14, 2013 1:06 am
by rs50pilot
I like how the lights are on then they go out then on again. Do you know how long it took?
Posted: Thu Mar 14, 2013 9:42 am
Did you read the description text on the video?
Posted: Thu Mar 14, 2013 10:05 am
by MorbidSlowBurn
Excellent.
Did the lower right space shift at the 0:37 mark? What is the dark surface you are printing on?
Posted: Thu Mar 14, 2013 10:23 am
Yes, one of the spacers came un-stuck from the bed during the print. I can't get the bed any hotter than about 83C (the target temp was 90C and it never reached that point - I suspect my wire diameter is insufficient (using 2 pair of 18ga)).
The material is window tint on a borosilicate glass bed, which in turn is on mhackney's aluminum spreader plate.
Posted: Thu Mar 14, 2013 10:32 am
by MorbidSlowBurn
Hadn't heard the window tint idea yet. How does it hold up under printing? How often do you have to replace? Are you also using hairspray or another binder?
I have a similar temp issue. Planning on installing another pair of wires when I install mhackney's plate. Just need to find time.
Posted: Thu Mar 14, 2013 10:58 am
It's my understanding that the tint material is PET tape, which has been recommended as a build surface. I've tried hair spray on the bare metal and it didn't turn out well. I've also tried hairspray on bare glass and that didn't work so well either. I strongly suspect the lower temperature to be a contributing factor to the print adhesion failures.
Posted: Thu Mar 14, 2013 12:24 pm
Hmm, I print on both aluminum and the borosilicate glass with hairspray at 70°C and it takes a sizable "POP" to get the parts off.
Posted: Thu Mar 14, 2013 1:08 pm
Try plating up a set of parts and try it. Single parts seem to be ok, but when you get away from the center the wheels come off.
