Page 1 of 2
LCD screen not coming up after successful flash
Posted: Mon Mar 18, 2013 6:44 pm
by bplemmons
I flashed my LCD controller for the Rostock and the Marlin firmware shows up in Repetier but I still only show white boxes on the screen, I have the new LCD adapter. are all of the instructions the same as the old one?
When I use the Arduino ide software to upload it says It's done but it doesn't reset to a working screen like the instructions say....:(
Bill
Re: LCD screen not coming up after successful flash
Posted: Mon Mar 18, 2013 7:26 pm
I am using Polygonhell's Repetier firmware and the LCD works fine with it. I tried to get Marlin to work several times with no success. I am not sure if anyone here is running Marlin and the LCD, hopefully someone will chime in if they are!
Posted: Mon Mar 18, 2013 8:12 pm
by bplemmons
Thank you!
I'll give it a shot....
Bill
Posted: Tue Mar 19, 2013 2:55 am
by bplemmons
Do I follow the same instructions for the Marlin firmware as far as adding and changing code for the marlin pin configuration settings? The files look different from what I have looked at...
Thanks again for your time....
Bill.
Posted: Tue Mar 19, 2013 4:23 am
by bplemmons
I see that it was configured for the rostock so I assume that I don't need to make all of those changes, but after loading the other firmware the lcd still does not function unless I have to change something else in the repetier firmware.....
Bill
Posted: Wed Mar 20, 2013 6:13 pm
by bplemmons
I still don't have a working LCD screen, I comes up with the white boxes but no words, I have checked and rechecked the directions and copied the new pin file, even tried the polygonhell firmware. Would someone look at my marlin firmware and possibly even try it to tell me what could be wrong, I would really appreciate it....
I have posted it as a zip file attachment, If it is good oters are free to use it if they don't want go through all of the editing....
Thanks guys!
Bill
Posted: Wed Mar 20, 2013 6:37 pm
by cambo3d
Hey bill,
I compared yours to mine using winmerge, the both our firmwares are exactly the same at least for the marlin pde. Although I have not powered up my board yet. I'll check the other files required files for the lcd to work.
I wonder if the problem lies in the adapter board or wiring.
have you tried maybe swapping the connectors around, John says it wont hurt the board,
Posted: Wed Mar 20, 2013 6:42 pm
by cambo3d
edit: I think i compared the wrong files let me try this again.
edit: I looked at all the required files. it seems correct, I'm no expert though.
I really need to power mine up to test but im not ready to do so yet.
can you post a picture of your adapter board?
Posted: Wed Mar 20, 2013 8:16 pm
by bplemmons
Here are the pictures of the adapter, John Olley soldered it himself and it looks perfect to me, I have tried to switch the cables but the screen won't come up at all that way...
I sent the file to John himself but he hasn't replied back yet.
Thank you for taking the time to look at the file and I would love for you to try it when you can....
Bill
Posted: Wed Mar 20, 2013 9:38 pm
by cambo3d
then its got to be the firmware, that photo matches my board also. If john is using this board and its working, he should be able to give us firmware to use it.
If yours isn't working, mine probably wont work either but imma give the firmware another look.
Posted: Wed Mar 20, 2013 10:24 pm
by bplemmons
Are you still building yours? Have you noticed if you onyx in warped? mine is. try laying a straight edge over it. mine is off by about 5/32. Even though I have a glass plate on order, I'm concerned that i wont get good heat transfer.....
Bill
Posted: Thu Mar 21, 2013 12:04 am
bplemmons wrote:Are you still building yours? Have you noticed if you onyx in warped? mine is. try laying a straight edge over it. mine is off by about 5/32. Even though I have a glass plate on order, I'm concerned that i wont get good heat transfer.....
Bill
PCB beds are never flat and if they are when cold they still wouldn't be when they heat up, it's one of the reasons you put glass or some other known flat substance on top.
The Onyx tends to bow upwards when heated, since the glass is clamped on the outside it shouldn't have an issue with contact.
Posted: Thu Mar 21, 2013 1:30 am
by cambo3d
hey bill try this one, I found some discrepanies in your marlin file.
maybe this one will work, its updated for rambo 1.1 rev, and lcd. let me know if it works.
if the lcd works, you will have to go back and update your configs again.
Posted: Thu Mar 21, 2013 5:46 am
by gabrielk
had the same problem with lcd on Marlin FW, but i do something like this using arduino 022 and changing pin file (exactly 022, not newer IDE)
in arduino IDE when you open any file from the project for example configuration.h all the files will be loaded. And i don't know if this make a difference if you open your marlin project by marlin.pde or another file, but for me it's working when I opened it by marlin.pde. And one thing more: when I downloaded Marlin-for-rostockmax-ramboLCD it won't work for me. I have to download Marlin-for-rostockmax-rambo and copy/paste all the setting from the Geneb manual, and everything is now working
and it worked, now i'm using repetier FW
Posted: Thu Mar 21, 2013 9:20 am
by cambo3d
gabrielk wrote:had the same problem with lcd on Marlin FW, but i do something like this using arduino 022 and changing pin file (exactly 022, not newer IDE)
do you have a copy of your working marlin firmware with lcd? I was working from the rambolcd wiki page and marlin master file.
I would like to compare it to the wiki to see if there is a difference.
Posted: Fri Mar 22, 2013 4:40 pm
by cambo3d
well just did a power up test and my lcd screen does the same as yours, just shows boxes.
I'm going to try it with a different arduino, arduino 22
Posted: Fri Mar 22, 2013 5:02 pm
by cambo3d
so i uploaded the firmware with both arduino 22, then tried arduino 23, I get the screen to show some letters, but i'm still getting boxes also
is this normal?
this is what the rambolcd wiki picture shows
Posted: Sat Mar 23, 2013 6:47 am
by magicmushroom666
I have an original Rambo from the indiegogo lot. have an early LCD too that didn't come with the rambo adapter.
I made up the lead as per the geneB LCD manual, and then made the same changes to the Marlin firmware to enable the LCD. It worked first time, compiled with arduino 23.
Posted: Sat Mar 23, 2013 6:06 pm
Might be a bad LCD, I have a 4x20 LCD I bought elsewhere that won't display anything on the bottom line, the LCD is just a serial device, normally I'd expect if you get anything displayed it would all work.
Posted: Sat Mar 23, 2013 6:24 pm
by cambo3d
I'm sending it back to seemecnc, for a replacement.
Posted: Tue Mar 26, 2013 11:54 pm
by bplemmons
Did you get yours working? I sent mine back for them to look at it.....
Posted: Wed Mar 27, 2013 12:32 am
by cambo3d
yep i got it working, it was a bad lcd, verified with a known good lcd. http://forum.seemecnc.com/viewtopic.php ... &start=160
Posted: Wed Mar 27, 2013 9:01 am
by jesse
I have a similar problem and will probably be sending it back to get tested.
[img]http://i.imgur.com/SSpo6sp.jpg[/img]
I ordered a replacement LCD on eBay ($8).
http://www.ebay.com/sch/LCDs-Displays-/ ... 0x4&_frs=1
Posted: Thu Mar 28, 2013 11:11 pm
by bplemmons
Turns out mine was bad too, they did send me a new one.....
Posted: Sat Mar 30, 2013 10:52 pm
by foshon
jesse wrote:I have a similar problem and will probably be sending it back to get tested.
Yours does exactly what mine does if I use John's Marlin file. Try the repetier firmware to see if it works. Something is wrong with John's LCD Marlin.
