Slicing with skeinforge causes slow movement
Posted: Sun Apr 07, 2013 6:43 pm
by RedWood
If i slice an object with skeinforge and run the job, the initial movement to the build plate is incredibly slow. If i left it to its thing, instead of clicking e-stop, it probably would have taken 20 too 30 min to reach the build plate. Has anyone experienced this or know what is wrong? I'm printing on Max with marlin firmware.
Re: Slicing with skeinforge causes slow movement
Posted: Sun Apr 07, 2013 9:28 pm
Look at the gcode and see what it output for feedrates. Most likely you have the rapid speed set too low.
Posted: Thu Apr 11, 2013 8:05 pm
by RedWood
Thanks for the fast response. Your comment caused me to again go over all the settings. I had "limit" set to 1 somehow.
Would have responded sooner but i just got my internet services up and running again. Woot.
Posted: Thu Apr 11, 2013 9:28 pm
Glad to help. As Occam's razor states "the simplest answer is usually to correct one."
