Questions about seeme repetier firmware
Posted: Thu Apr 18, 2013 11:08 pm
by bplemmons
I have 2 questions about John's new repetier firmware:
How do you change the speed on the lcd controller?
How do you save to the SD card? It says file name not 8.3 compatible....
Bill
Re: Questions about seeme repetier firmware
Posted: Fri Apr 19, 2013 2:47 am
by Jimustanguitar
The file name is a little bit special. I believe that you're limited to 9 characters (somebody correct me if i'm wrong) and it needs to be a .gco file extension instead of .gcode
You can load to the SD card via USB while connected to the Rambo with Repetier, or you can load a 9digit.gco directly to the card. Using your laptop's card reader is faster, but loading the card through Repetier is convenient depending on the size of the file.
Nt sure about the speed, but it is possible, I've seen it done :)
Posted: Fri Apr 19, 2013 11:08 am
I suspect the filename is restricted to the DOS 8.3 format due to the filesystem on the SD card.
