hot end clogged with metal pieces
Posted: Mon Apr 29, 2013 8:41 am
by DaGroundZero
My hot end jammed and the tube going into the top of the hotend had came out. I started looking and I found a few little chunks of metal at the top of the lining tube.
These look like they came from the screw thingy. The hot end is jammed up and I can't seem to get the nozzel off. Any suggestions on how to remove the brass Moseley?
Re: hot end clogged with metal pieces
Posted: Mon Apr 29, 2013 9:43 am
Heat it up and use a pair of channel-locks to hold the lower section of the hot end while you remove the nozzle with a wrench.
Take care not to damage the resistors or thermistor.
Posted: Mon Apr 29, 2013 10:57 am
by DaGroundZero
I tried that and ended up ripping of a wire on the thermistor. Looks like hot end rebuild time. I still need to get the nozzle off too. dang the bad luck.
Posted: Tue Apr 30, 2013 10:48 am
Yeah, you need to be VERY careful where you grab that thing. It's easier to deal with if you remove the hot end from the effector platform.
Don't feel bad though, I blew my first thermistor in half when I shorted it out against the power leads going to the resistors. :)
Posted: Thu May 02, 2013 1:25 pm
by DaGroundZero
I received my replacement parts yesterday. I opted to go with a new hot end. I should be printing again tomorrow which is just in time for the weekend.
*** correction. With the new cartridge, I used my high temp tape and put the heating cartridge in place. It took about 5 minutes to get re calibrated, and I'm printing my second print now. The cartridge seems to show a nice even heating curve. So far, it is a keeper.
