EZ Struder instructions?
Posted: Sat May 25, 2013 12:16 pm
by jesse
Does anyone have instructions on how to assemble the EZstruder?
Re: EZ Struder instructions?
Posted: Sat May 25, 2013 12:26 pm
Jesse, please see Section 12 in this draft of the 2nd edition manual: http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
Posted: Thu May 30, 2013 11:54 am
by jesse
Thanks Gene.
What changes need to be made to the firmware to support the EZ Struder?
Posted: Thu May 30, 2013 3:44 pm
by Jimustanguitar
E0 steps per mm. (or E1, if you have it wired that way) I don't know what the proper value should be.
You could probably also do some speed and acceleration tweaks.
Posted: Wed Jul 17, 2013 11:51 pm
by MWProtoType
Can someone identify what screws are to be used here? None of the ones remaining in my kit seem to work.
Posted: Thu Jul 18, 2013 7:16 pm
You should have 1 2" #6-32 and 1 1.75" #6-32 pan head screw. Use those and two #6-32 nylon lock nuts.
Posted: Thu Jul 18, 2013 10:36 pm
by MWProtoType
thanks,
