Hot end and Heat Bed Issue!
Posted: Wed Oct 30, 2013 10:03 pm
by jonyzdude
When I completed building my rostock I made sure that the hot end and the heat bed functioned properly in which case they did. After having to Emergency stop my process because I had a hot end Jam from the Filament I had to take it apart. Two weeks later I put the hot end back on and started the machine up. I tried heating the hot end and heat bed but nothing happens. The green lights that usually come on on the RAMBO don't. This is what my log is saying.
21:34:01.667 : start
21:34:01.823 : External Reset
21:34:03.944 : SD init fail
21:34:03.960 : Printed filament:0.65 m
21:34:03.960 : Printing time:0 days 0 hours 49 min
21:34:04.038 : extruder 0: temp sensor defect
21:34:04.038 : heated bed: working
21:34:04.038 : Printer set into dry run mode until restart!
21:34:13.164 : start
21:34:13.351 : External Reset
21:34:15.457 : SD init fail
21:34:15.473 : Printed filament:0.65 m
21:34:15.473 : Printing time:0 days 0 hours 49 min
21:34:15.566 : extruder 0: temp sensor defect
21:34:15.566 : heated bed: working
21:34:15.566 : Printer set into dry run mode until restart!
21:34:16.970 : Printed filament:0.65 m
21:34:16.986 : Printing time:0 days 0 hours 49 min
21:47:30.913 : start
21:47:31.084 : External Reset
21:47:33.206 : SD init fail
21:47:33.221 : Printed filament:0.65 m
21:47:33.221 : Printing time:0 days 0 hours 49 min
21:47:33.299 : extruder 0: temp sensor defect
21:47:33.315 : heated bed: working
21:47:33.315 : Printer set into dry run mode until restart!
21:47:34.750 : Printed filament:0.65 m
21:47:34.750 : Printing time:0 days 0 hours 49 min
21:47:50.522 : extruder 0: temp sensor defect
21:47:50.522 : heated bed: working
21:47:50.522 : Printer set into dry run mode until restart!
21:50:03.028 : extruder 0: temp sensor defect
21:50:03.028 : heated bed: working
21:50:03.028 : Printer set into dry run mode until restart!
21:52:57.270 : extruder 0: temp sensor defect
21:52:57.270 : heated bed: working
21:52:57.270 : Printer set into dry run mode until restart!
21:52:58.830 : extruder 0: temp sensor defect
21:52:58.830 : heated bed: working
21:52:58.830 : Printer set into dry run mode until restart!
Im not sure what the problem is, hence me posting this, any help would be greatly appreciated.
Jon
Re: Hot end and Heat Bed Issue!
Posted: Wed Oct 30, 2013 10:22 pm
by cope413
Looks like you damaged your thermistor connection in the hot end when you took it apart. Check your thermistor wires/connections and you'll find the problem.
