Arms Don't Line Up with Metal Legs
Posted: Tue Dec 17, 2013 8:26 pm
by brbubba
Re: Arms Don't Line Up with Metal Legs
Posted: Tue Dec 17, 2013 9:07 pm
by int2str
Look at your printer straight on from the LCD display side. Only the rear post (Y) is "straight" on the Y axis. The front two posts are not directly on an axis, but are 120 degrees offset. Therefore, if you send the printer to "Yxx X0", it will line up with the rear upright. But if you send it to "Y0 Xnn" it will not be inline with any other upright.
So, try these:
- Rear post (Z5...)
G0 Z5 X0 Y90 F3500
- Right post
G0 Z5 X-77.94 Y-45 F3500
- Left post
Posted: Tue Dec 17, 2013 9:35 pm
by bubbasnow
how big (mm) is the orion bed?
Posted: Tue Dec 17, 2013 10:03 pm
by brbubba
int2str wrote:Look at your printer straight on from the LCD display side. Only the rear post (Y) is "straight" on the Y axis. The front two posts are not directly on an axis, but are 120 degrees offset. Therefore, if you send the printer to "Yxx X0", it will line up with the rear upright. But if you send it to "Y0 Xnn" it will not be inline with any other upright.
So, try these:
- Rear post (Z5...)
G0 Z5 X0 Y90 F3500
- Right post
- Left post
I think I've been inhaling too many plastic fumes. Thanks, worked like a charm.
EDIT: I think sometimes you get so involved in looking at a problem a certain way that basic logic goes out the door...
Posted: Wed Dec 18, 2013 2:00 pm
Considering all Orions are properly calibrated before they're shipped, I'm kind of confused as to why you'd try to "recalibrate" it in the first place.
Posted: Wed Dec 18, 2013 2:18 pm
by int2str
geneb wrote:Considering all Orions are properly calibrated before they're shipped, I'm kind of confused as to why you'd try to "recalibrate" it in the first place.
I recalibrated mine. The center was slightly too low squashing the first layer in the center. I've adjusted my PRINTER_RADIUS by 0.4.
Just because it comes plug & play doesn't mean there's nothing to gain or at least to be learned by going a bit more hands-on
Posted: Wed Dec 18, 2013 2:47 pm
by Nylocke
That should have just been an endstop adjustment....
Posted: Wed Dec 18, 2013 4:04 pm
by int2str
Nylocke wrote:That should have just been an endstop adjustment....
No. The center was lower than the outsides.
Posted: Wed Dec 18, 2013 5:34 pm
by Nylocke
Ok, your weren't exactly specific, if its printing level now then good on you mate.
Posted: Wed Dec 18, 2013 10:28 pm
by brbubba
UPS beat the crud out of it when I received it, so I had to do Z height calibration and I also did calibration for each leg with the screws.
