Hot End Not Working
Posted: Sat Feb 08, 2014 6:55 pm
by aerouta
My hotend is no longer working. I have checked the voltage at the “Heat 0” terminal on the Rambo and I get zero. I checked all the terminals at main power port and they show 12v as expected. Repetier shows max power being sent to the hotend.
I changed the line in the config file from
#define EXT0_HEATER_PIN HEATER_0_PIN
To
#define EXT0_HEATER_PIN HEATER_1_PIN
And still got zero on HEAT 1 terminal.
also checked the F3 fuse.. should there be 12v across the F3 fuse?
Any suggestions??
Re: Hot End Not Working
Posted: Sat Feb 08, 2014 7:34 pm
You did not say if you checked the small fuses.
Turn the power off and pull the small fuses.
Check them for continuity. They should read 0 ohms.
Posted: Sat Feb 08, 2014 7:56 pm
by aerouta
fuses have continuity
Posted: Sat Feb 08, 2014 8:00 pm
by aerouta
I am at a loss here...
Posted: Sat Feb 08, 2014 8:15 pm
by aerouta
It was F3 after all. I got heat!
Another question, should both LED2 and LED4 light up while heating a single extruder? I have never paid attention to this before.
Posted: Sat Feb 08, 2014 9:13 pm
I think SeemeCNC set the second one to turn on a fan.
