UPDATE: Sorry Neurascenic, no pictures on the belt position because I ran other tests and am narrowing things down -- a little
I stand up a battery on the platform (after it draws perimeter line) to where the extruder plate just touches the battery when it prints the outer perimeter of the box, in line of the direction that the parts have been leaning toward.
When I print in DRY RUN with no plastic - the clearance between the extruder plate and the batter remains the same, from bottom to top and no clicking is heard
BUT, when i print with plastic
I do hear clicks now and then, indicating 'something' is slipping.
When I hear the clicks, that's when the extruder is shifting over, after the click then the battery will move over as the outside perimeter is printed, because the extruder has shifted.
BUT, I checked and checked - the Clicking is coming from the EXTRUDER Stepper - not one of the Towers.
And, the shifting is always Away from the Z axis.
I have checked all the gears - i had lock tight on the threads, so they were really hard to break loose, but, I unthreaded them and then retightened them - especially the ones on the flat part of the stepper shaft. They were and again are on Tight, they aren't slipping on the shaft. I haven't perceived the belt slipping on the gear threads, although I will run a few more tests on it, but that isn't where the clicking sound is coming from.
But, 'something' has to be slipping in relation to the Axis - somewhere.
Since the Clicking sound is from the filament extruder, and is when the extruder is backing off, or retracting, i think to go up to the next layer, i am suspecting this is more electrical / electronics related then mechanical (or the mechanical is causing an electrical interference).
If it is related to the filament extruder retraction, then I can think of 2 paths where the Z axis is slipping :
1) would be that the plastic is not retracting easily, and when the extruder tries retracting it, it is Physically pulling up on the extruder platform so hard that it is causing one of the tower steppers (Z axis) to slip on the belt.
2) there is an electrical problem - where either there is a weak electrical connection where the Z axis stepper is functioning normally most of the time, but, when there is extra current draw from the extruder retraction it is enough to sometimes deprive the Z axis of enough current that it can't step at that time.
If it were scenario 1) then i would think i would hear a click on the Z axis as the belt would be jumping a tooth at that time, OR if the gear wasn't tight on the shaft, it could be slipping at that time. But, I don't hear a click on any of the tower steppers at that time, and I've totally taken out and re-tightened the gear set screws, i am 99.99999% sure it is not a slipping gear (hey, there is always that small chance the threads are damaged and the set screw gets tight, but not against the shaft, but, I just don't think that is happening, but again, i'll recheck it again).
If it's scenario 2), then there might be a number of causes and places to look.
It could be a weak electrical connection on the Z stepper connector
It could be a defective Z stepper motor
It could be that the plastic is putting up too much resistance to retracting that it is drawing excessive current drain, causing the Z axis to not get enough current at that time.
It could be a bad Rambo board / stepper driver
It could be a weak / bad Power Supply
It could be a bad wire connection from the power supply
Please help me out if you can think of other things to add to the IT Could Be list, and other things to check.
Also, HOW to i go about checking these things? Especially the steppers?
I have a 'slow' LCD DMV meter that checks amperage, but, that would mean disconnecting the wires and checking current inline, but, it is slow to measure, so i think it would be useless. I don't have a scope, but, I have a number of mini aduino boards and I have a arduino sketch and program that outputs the A/D inputs on the arduino to a GUI windows interface that allows me to have a 4 (or 6) channel scope . 0-5 volt without using any resisters to cut down the voltage. It will take a few hours to set it up, but, I am thinking of using it to see what the voltages to the steppers looks like, only if i have to,
Or is there an easier way to check steppers / etc?
In EEProm the Ext1 Steps per mm = 92.65
Attached is screen shot of the Slic3r extruder settings
I noticed that in the manual controls on repetier it has retract set to 100 mm is that correct?
