(Solved) Extruder "clicking" after printing
Posted: Thu Mar 06, 2014 5:04 pm
by Lasivian
I am getting a tiny jerk and a click after I print things.
Triffid_hunter in #reprap said this is likely due to the stepper driver overheating.
But I am seeing that on the Rambo the current is set digitally not with a pot. So I am assuming it is correct.
Suggestions/ideas?
EDIT: The thermistor seems to be off and the heat was too low (Even when it says 210c) for the .35 nozzle so the motor kept trying to force the filament.
I suppose this should be moved to the troubleshooting forum.
Re: Extruder "clicking" after printing
Posted: Thu Mar 06, 2014 5:41 pm
Edited, superceded.
Posted: Thu Mar 06, 2014 5:44 pm
I wouldn't reduce it at all. I'd add a cooling fan to the back wall of where the RAMBo is mounted, or print that neat fan shroud that Chrissi designed that fits in the LCD door.
Posted: Thu Mar 06, 2014 5:52 pm
by Lasivian
geneb wrote:I wouldn't reduce it at all. I'd add a cooling fan to the back wall of where the RAMBo is mounted, or print that neat fan shroud that Chrissi designed that fits in the LCD door.
Do you have a link to this at all? I cannot seem to find it.
Posted: Thu Mar 06, 2014 6:23 pm
by Lasivian
Eaglezsoar wrote:Edited, superceded.
that was good info, why did you remove it?
Posted: Thu Mar 06, 2014 7:13 pm
Lasivian wrote:Eaglezsoar wrote:Edited, superceded.
Because it was superseded by others who apparently had better ideas.
Posted: Fri Mar 07, 2014 9:09 am
Hey Chrissi! Can you post a link to that slick LCD door fan shroud you designed? I can't find the link either.
Posted: Fri Mar 07, 2014 4:51 pm
by Lasivian
I finally found it
http://forum.seemecnc.com/viewtopic.php ... 104#p31104
For now tho leaving the LCD door open seems to give it enough air.
