Problem with same layer every time!
Posted: Sat Sep 13, 2014 2:43 am
by GeekStreetSolutions
I have been trying to figure out this problem for weeks, (I attatched some photos for reference and the stl file). Here is a list of facts and some of the problems I am running into:
• The print head seems to do one of two things at the same height every time.
o The print head will either go too high and the filament wont stick.
o Or it will shift the whole print one direction causing the rest of the print to be misaligned.
• The errors seem to happen right after the center area reaches its max height and the corners begin to print to their final height.
• This seems to only happen with this model and any other model will not run into any problems.
• The belts are not stripped and they are properly tightened.
• I have used multiple settings and many different slicers, same result.
I am going crazy! Does anyone know what is happening?
Re: Problem with same layer every time!
Posted: Sat Sep 13, 2014 6:50 am
by teoman
Have not experienced this. But your pulleys may be shifting on the motor shafts...
Posted: Sat Sep 13, 2014 7:41 am
by Holy1
Run the model through netfab to see if it has errors. If the model has issues then it doesn't matter which slicer you use. You say the printer is fine with different models so machine error is unlikely.
Hope that helps.
Posted: Sat Sep 13, 2014 10:27 pm
I forgot to mention I have already tried running it through netfab, same results.
Posted: Sat Sep 13, 2014 10:43 pm
by DavidF
I down loaded your files, sliced the stl in cura, and really dont see anything obvious. I really cant tell anything from your picture either. But when you said that the print gets off set....Now there may be something. What material are you printing in? Could it be you are getting snagged up on the top layers or something??
Posted: Sun Sep 14, 2014 12:08 am
Ive tried 3 different rolls of abs and now I am using pla. I forgot to put the link to where I got the model from earlier so here it is: http://www.thingiverse.com/thing:315348
Posted: Sun Sep 14, 2014 3:56 am
by teoman
I will try printing them today and report back.
Posted: Sun Sep 14, 2014 1:33 pm
teoman wrote:I will try printing them today and report back.
Thanks for all your help. If you do get a successful print would you mind posting the sliced file and your settings?
Posted: Sun Sep 14, 2014 9:07 pm
Would re flashing the firmware be a way to rule out any problems?
Posted: Tue Sep 16, 2014 9:04 am
by teoman
Sorry, work got in the way and i could not print the part yet.
Have you figured it out? If not i will fire the printer up in 4-5 hours.
Posted: Tue Sep 16, 2014 11:50 am
Nope, I stlill am having problems.
Posted: Wed Sep 17, 2014 3:49 pm
by teoman
Sorry for the delay. I have fired up the print. Matter control claims 6+ hours. I sure hope it is ready by the time i jave to leave for work. And that my printer doesnt picass.
Posted: Wed Sep 17, 2014 4:00 pm
I've moved my printer into a different room and am going to re calibrate everything and retry the print also. Im starting to think that using multiple slicers and computers may have done something to the eeprom and resetting everything to default and calibrating will confirm if that is the problem or not.
Posted: Wed Sep 17, 2014 11:58 pm
by teoman
And it went picasso on me.
i must have knocked some of the clips in a hurry. The glass bed moved. :)
