Source for 4mm Quick Connect PTC Fittings...
Posted: Sun Sep 14, 2014 11:02 pm
by netdefilr
I had an issue with a clog in my bowden tube. Well after trying to fix the issue, I need a PTC fitting replacement. Seemecnc is sold out.
But I'm not coming up with an exact replacement. Can someone more savvy with buying these parts steer me in the right direction?
Re: Source for 4mm Quick Connect PTC Fittings...
Posted: Mon Sep 15, 2014 1:14 am
by bubbasnow
Posted: Mon Sep 15, 2014 1:27 am
by Generic Default
I'm not 100% sure about this, but it may make sense to buy one that's rated for a higher pressure. These things are notorious for breaking and it makes logical sense to me that a higher pressure unit would be stronger and more durable. The amazon ones are only rated at 145 PSI.
I bought a bunch for experimenting with a few days ago from McMaster.
http://www.mcmaster.com/#push-to-connec ... gs/=tq8j5r
Posted: Mon Sep 15, 2014 6:04 am
by McSlappy
I found some here locally (not that the source helps you) and I mention it only because they have zero play when connected with my bowden while the stock ones have a tiny amount of play.
Posted: Mon Sep 15, 2014 7:54 am
by netdefilr
Generic Default wrote:I'm not 100% sure about this, but it may make sense to buy one that's rated for a higher pressure. These things are notorious for breaking and it makes logical sense to me that a higher pressure unit would be stronger and more durable. The amazon ones are only rated at 145 PSI.
When I go to the link it's to these types of parts in general. Do you know what to click on or have a more specific link to the correct part?
Posted: Mon Sep 15, 2014 8:16 am
McSlappy wrote:I found some here locally (not that the source helps you) and I mention it only because they have zero play when connected with my bowden while the stock ones have a tiny amount of play.
You have to find out what those are. Zero slop is the bowden tube holy grail.
Posted: Mon Sep 15, 2014 9:24 am
by jesse
Posted: Mon Sep 15, 2014 11:01 am
by netdefilr
Any USA source? Could take forever from Hong Kong.
Posted: Mon Sep 15, 2014 2:10 pm
by jesse
SeeMeCNC sells them:
http://seemecnc.com/collections/parts-a ... tc-fitting
Posted: Mon Sep 15, 2014 6:19 pm
by Mac The Knife
You obviously didn't read the first post.
Posted: Mon Sep 15, 2014 11:35 pm
by netdefilr
Turns out they got them back in stock this morning. Thanks for the help guys.
