hot end and bed not heating
Posted: Wed Oct 29, 2014 1:34 am
by timochief
My temp on extruder is showing 366 when I turn printer on . It then goes to def . No lights showing hot end heat and bed heat.
Re: hot end and bed not heating
Posted: Wed Oct 29, 2014 1:49 am
by Earthbound
Check the thermistor wiring. RAMBo can't read extruder temp so won't turn on heat.
Posted: Wed Oct 29, 2014 1:52 am
by Earthbound
If you have a multimeter, you can check the thermistor circuit by unplugging the lead from the RAMBo and reading the thermistor's resistance which should be about 100kohm.
Posted: Thu Oct 30, 2014 10:09 pm
by tbone_atl
I had exact same issue...same value of 366 even. Continuity test (stuck pins in the quick connector) proved that there was a short. I figured the leads of the thermistor were probably touching somewhere inside the RTV...luckly I looked at my poor crimping job (where the connector meets RAMBO) and realized I had a strand of copper wire that was touching the other crimp pin. removed it and I was in business.
