Smoking hot end.
Posted: Mon Nov 10, 2014 8:22 pm
by MARSTECH
I was in the process of installing the firmware; when I realized a burning smell. I look over and my hot end was steaming, and it smelled like it was burning. Is this normal? Or should I be worried? Thanks for all the help in advance.
Re: Smoking hot end.
Posted: Mon Nov 10, 2014 8:36 pm
by Earthbound
It is not normal to have the hot end even get warm until you switch it on, which doesn't happen until after you've installed the firmware and start the hot end tuning process.
I don't have any immediate thoughts about what you need to check, so I'm not going to be a lot of help at this point. The short answer is no, something seems to be wrong.
Posted: Mon Nov 10, 2014 8:39 pm
by Earthbound
A _little_ smoke from the hot end the first time it is switched on is not unusual. The trouble here is that it shouldn't have switched on yet.
Posted: Tue Nov 11, 2014 3:14 am
by bubbasnow
be sure to check your peek and ensure its not damaged.
