Weird .92 homing behavior?
Posted: Mon Nov 24, 2014 8:29 pm
It doesn't always happen, but when I home my printer sometimes it will make this loud slamming noise. I only noticed it after installing .92 repetier. I'm sure if I were to switch back it would be fine. Its like something is bumping the carriages/effector when it moves into the extruder offset position and moving them all <1mm down. This makes things very frustrating, I've had to restart the same print several times just to get a good first layer.
I did notice if I lightly held my hand against the effector it wouldn't make the noise and it wouldn't move down. One of the times I did this (at the beginning of a print) I, while applying very little pressure, was able to push the whole carriage assembly towards the Y tower. This was completely accidental, and was caused by me just trying to keep very light pressure on the effector to prevent the issue. I'm wondering if there is a bug that causes the stepper drivers to limit (or even cut out) the amount of current going to the steppers directly after a G28 command? Or maybe its simple as my stepper drivers are broken? I have some new fancy ones coming in from Panucatt so that second option will be tested out sometime soon.
Does anyone know what could be causing this?
