Homing after print job
Posted: Wed Dec 03, 2014 8:26 pm
by Weezel
After I finish a print job, my rostock v2 max goes nuts on me and the hot end ends up travelling way out to somewhere past the y axis until the y axis arms get stuck and can't move anymore.
I tried searching the forums for answers, but I did not come up with any. Otherwise, the prints look fine.
I'm using the latest rambo firmware and repetier host for mac.
Re: Homing after print job
Posted: Wed Dec 03, 2014 8:49 pm
by bot
I had that probelm with marlin and an old home built rostock. It was because it wasn't homing all axes. There was a variable that needed to be set to indicate it must home all axes.
Posted: Wed Dec 03, 2014 9:15 pm
by Weezel
Okay, i'll root around in the c code to look for that. Any idea where that variable is set?
Posted: Thu Dec 04, 2014 12:46 am
by bot
I have barely had a need to poke around in there, but I would do a search for "hom" and you should stumble upon it.
Posted: Thu Dec 04, 2014 11:01 am
It's got nothing to do with the printer at all. I'm willing to bet you've got the "go to park position" checkbox set in the host software. Do yourself a favor and install MatterControl for MacOS.
Posted: Thu Dec 04, 2014 12:34 pm
by Hydrolove
My printer is doing something similar. After it finishes a print it will go to the home position then it drives to the max position between the Y and X tower. I haven't looked into it and I am just homing it to re-position it. I am running Repetier-Host but have plans to move to Matter Control and will see if the odd behavior goes away.
