Help Needed! - New Build: Power Issues Part 2
Posted: Wed Dec 10, 2014 7:40 pm
by beilmandesign
My Max 2 new build was shutting down when I turned on either of the heats. SeeMeCnc said it was a power supply issue and shipped me a new one. I installed it tonight, but now the LCD display comes on for a second then goes dark. The rambo fan and status light are on in that split second.
Any ideas?
Re: Help Needed! - New Build: Power Issues Part 2
Posted: Wed Dec 10, 2014 8:05 pm
by BenTheRighteous
Did you create a short circuit when you installed the new psu?
Posted: Wed Dec 10, 2014 8:16 pm
by beilmandesign
Checked everything & was very careful when installing psu #1 and #2
Posted: Wed Dec 10, 2014 8:34 pm
by beilmandesign
I opened up the power supply and found some bridging across the ac input contacts. I cleaned this up and separated all the component leads that seemed to be touching. The p/s still will not stay on.
Posted: Thu Dec 11, 2014 4:50 pm
by beilmandesign
If you cut your main atx connector off be sure that you connect the brown wire to any orange wire. It is needed to prevent the issue I noticed in the 1st line above. JJ at SeeMeCNC alerted me to this and now all is well.
Posted: Thu Dec 11, 2014 5:04 pm
Please tell me where the manual tells you to cut off the whole ATX connector.
Posted: Thu Dec 11, 2014 7:02 pm
by JFettig
geneb wrote:Please tell me where the manual tells you to cut off the whole ATX connector.
It didn't tell me to desolder all of the extra wires from the power supply but I did
