Top mount dual extruders
Posted: Mon Mar 09, 2015 2:34 pm
by JFettig
Here is my setup I've been running for a little while.
[img]http://i.imgur.com/BxuCYfU.jpg[/img]
[img]http://i.imgur.com/BRopcqR.jpg[/img]
Its loosely based off of various things I've found, including BenTheRighteous' extruder top mount.
http://repables.com/r/518/
I may have my top plate on upside down or something - I believe it is how the manual is written though. One hole had to be drilled out - an existing screw hole for the second extruder bowden to pass through.
Re: Top mount dual extruders
Posted: Mon Mar 09, 2015 2:42 pm
Nice and clean. Well done!
Posted: Tue Mar 10, 2015 3:18 am
by Renha
looks great! Maybe it's best solution one could use when only 2 extruders are needed
Posted: Tue Mar 10, 2015 6:26 am
by 3D-Print
Very nice. And keeps the steppers out of the enclosure and heat.
Posted: Tue Mar 10, 2015 3:06 pm
by 3D-Print
What do you use to control your two steppers. Is there an optimal software that allows you to turn on and off one or the other steppers? Just haven't run into that yet.
Posted: Tue Mar 10, 2015 4:17 pm
by JFettig
What do you mean? The firmware and slicer take care of the steppers and heaters.
Firmware setup: http://forum.seemecnc.com/viewtopic.php ... 942#p60942
There are 2 stepper inputs for extruders on the RAMBO board and 2 hot end heater outputs as well as 4 thermistor inputs.
Posted: Tue Mar 10, 2015 4:41 pm
by 3D-Print
JFettig wrote:What do you mean? The firmware and slicer take care of the steppers and heaters.
I was wondering if the software existed to control the extruders such that based on the layer or the specific aspec of the print you automatically extrude the filament of choice.
Posted: Tue Mar 10, 2015 5:39 pm
by JFettig
yes, most slicers have the ability to do some form of that dependent on what you input.
