Upper teeth
Posted: Mon Oct 12, 2015 1:50 pm
Full size upper set of human teeth with Polymax, 50% infill, 0.2mm layer, print time less than 1 hour.
Have a look around and join today!
https://download.seemecnc.com/
Eaglezsoar wrote:Makes me wonder if a full set of dentures can be 3d printed and carved to fit the human mouth, interesting!
Good point that I didn't think about, I would not want all those nasties growing in my dentures.barry99705 wrote:Eaglezsoar wrote:Makes me wonder if a full set of dentures can be 3d printed and carved to fit the human mouth, interesting!
They already use sinter based printers to make molds and models for permanent replacements. I don't think you can use an extrusion based printer to make food safe products. Crap is going to grow in the voids.
You are right again Captain. Even modern dentures are subjected to incredible forces by the human jaws. I bit into a hard nut not so long ago and my upper denture cracked down the middle!Captain Starfish wrote:Not to mention strength issues - there are some incredible forces generated on the teeth which I suspect would destroy any kind of filament we print with in days or less.
They're easier on your teeth if you take the nuts out of the shell first...Eaglezsoar wrote:You are right again Captain. Even modern dentures are subjected to incredible forces by the human jaws. I bit into a hard nut not so long ago and my upper denture cracked down the middle!Captain Starfish wrote:Not to mention strength issues - there are some incredible forces generated on the teeth which I suspect would destroy any kind of filament we print with in days or less.
I learned that the jaw muscles exert tremendous forces and that nuts should not eat nuts!
Makes halloween so much more fun too!teoman wrote:You have the printer... set it to print a new every morning.
No more brushing and you can eat nuts all day long provided you have a couple of spares
So that's what caused it! I forgot to take the shell off the nut first! I am ever grateful for telling me that!barry99705 wrote:They're easier on your teeth if you take the nuts out of the shell first...Eaglezsoar wrote:You are right again Captain. Even modern dentures are subjected to incredible forces by the human jaws. I bit into a hard nut not so long ago and my upper denture cracked down the middle!Captain Starfish wrote:Not to mention strength issues - there are some incredible forces generated on the teeth which I suspect would destroy any kind of filament we print with in days or less.
I learned that the jaw muscles exert tremendous forces and that nuts should not eat nuts!![]()
also, 55 to 200 psi depending on where you measure the force in your jaw, strongest toward the back.
You always make me laugh.geneb wrote:It's the 5/16" Zinc ones that always get me.
keokolo wrote:3D systems and Stratsys have a line of dental 3D printers. They are mainly for making molds from dental scans. The pipeline is still being worked out but the dental labs are going to shrink. The print was mainly a test of PolyMax, not intended for final use although it would be just fine for costume teeth. It was inspired after reading about this Chinese FFM SLA viscous material printer being able to 3D print porcelain, very fast, hundreds of times faster than FDM.
http://www.innovationtoronto.com/2015/0 ... n-minutes/
Chinese researchers make breakthrough in SLA 3D printing, soon be able to 3D print porcelain teeth in minutes
Jimustanguitar wrote:Yep, 3D printed dentures is already a thing. One of the guys at The Hive has done some work on resins for that kind of printing.
https://www.facebook.com/themakerhive/p ... permPage=1
